-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   remove fixed pane slider (http://www.diychatroom.com/f104/remove-fixed-pane-slider-157751/)
sacseven 09-23-2012 04:40 PM
2 Attachment(s)
How do I take the fixed pane out?? I have remove the trim pieces, just not sure what to do next. Does not appear there are any fasteners holding it in place. What do the experts think?
FYI_
allready lowered wheels, etc. Window will not lift out. Builders aluminum dual pane circa 1992.
sixeightten 09-23-2012 04:57 PM
It is probably screwed in through the back side of the frame
chb70 09-23-2012 05:00 PM
If it has the leveling wheels, you should be able to lift it out.
The older units did not have much clearance and you may need to pry the s*%t out of it.
chb70 09-23-2012 05:05 PM
Just want to make sure, are you are able to move the pane side to side or is it still locked into place.
sacseven 09-23-2012 05:51 PM
Fixed pane is still locked in to place. I can not find any screws where it attached to frame.
Do I want to focus on prying up first or from behind.
I am assuming that the sliding pane needs to have the fixed pane remove in order to be taken out.
Not sure if it has leveling wheels, I unscrewed the wheels completely and they are no long visible.
oh'mike 09-23-2012 06:44 PM
The moving door always gets removed first and installed last----
chb70 09-23-2012 10:19 PM
If it is screwed through the back side of the frame, you would not be able to get to them. The frame side is against the wall, if that is the case then I would try to pry the frame away from the wall on the top and bottom, and try to break the screws from the frame.
