Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-24-2012, 12:15 PM   #1
Remove deadbolt with no screws.
I am trying to remove an old deadbolt without screws. I have tried to remove the old faceplate and cannot get it off. I've even tried a chisel and hammer. I have loosened the bolt and can turn the out ring of the deadbolt, but still have no success getting it off the door. Any suggestions?
serpak9 is offline   Reply With Quote
Old 03-24-2012, 12:19 PM   #2
Need a picture!
If you had of left the trim ring on in most cases there's a small hole, could be round or rectanguler shaped that you just stick a small flat screw driver in and the trim ring just pops off. It will be on the inside part of the dead bolt.
Old 03-24-2012, 01:16 PM   #3
Here are pictures of the front, back and door edge of the deadbolt. As you can see from the scratches - I have tried to "pop" off the face plate - it does not come off.
Old 03-24-2012, 01:27 PM   #4
Look on the shaft that the trim rings is where you have been chisling. See any threads. I've seen one brand that the ring screwed on.
Old 03-24-2012, 02:11 PM   #5
I don't see any threads - I was able to remove a little more of the steel face plate and tried to get a closer picture. I tried to drill through the key hole - but I don't have a strong enough drill and bit.
Old 03-24-2012, 02:48 PM   #6
the Musigician
DangerMouse's Avatar
Double keyed DB? Try two pair of vice-grips/pliers, one on each side of the door and unscrew them.
That should do it.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-24-2012, 05:02 PM   #7
The deadbolt turns and turns and turns, but does not unscrew. Not sure what else to try at this point. :-)
Old 03-24-2012, 05:20 PM   #8
the Musigician
The OUTER RINGS turn and turn while holding them both with pliers?
Impossible.
DM
Old 03-24-2012, 05:54 PM   #9
I took a video but I can't seem to upload a video to this site. The outside knob turns just a little bit and then sticks. The other side continues to turn, but nothing happens, like turning a screw with stripped threads.
Old 03-24-2012, 06:00 PM   #10
the Musigician
If it's that messed up and stripped, try a sawzall with a metal blade and slice off one side. It'll fall off.
DM
Old 03-24-2012, 10:50 PM   #11
Do you have a Dremal tool? Use a cut off wheel to split the trim ring.
It would do less damage to the door then a sawall.
Old 03-25-2012, 07:39 AM   #12
the Musigician
Wrong. Exactly the opposite. If done correctly, a sawZall, cutting parallel to the face of the door, will never touch it. Whereas a round cutting wheel on a DremEl tool could easily damage the face of the door.
DM
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 09:19 PM
Any locksmiths out there? Trying to remove Weiser deadbolt handeman Windows and Doors 11 11-12-2011 05:32 AM
Cant remove old door knob...? toicy4ya Carpentry 11 09-06-2011 07:52 PM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 09:20 PM
