-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Remove deadbolt with no screws. (http://www.diychatroom.com/f104/remove-deadbolt-no-screws-138066/)
serpak9 03-24-2012 12:15 PM
I am trying to remove an old deadbolt without screws. I have tried to remove the old faceplate and cannot get it off. I've even tried a chisel and hammer. I have loosened the bolt and can turn the out ring of the deadbolt, but still have no success getting it off the door. Any suggestions?
joecaption 03-24-2012 12:19 PM
Need a picture!
If you had of left the trim ring on in most cases there's a small hole, could be round or rectanguler shaped that you just stick a small flat screw driver in and the trim ring just pops off. It will be on the inside part of the dead bolt.
serpak9 03-24-2012 01:16 PM
Remove Old Deadbolt with no screws
3 Attachment(s)
Here are pictures of the front, back and door edge of the deadbolt. As you can see from the scratches - I have tried to "pop" off the face plate - it does not come off.
Attachment 48052
Attachment 48051
Attachment 48053
joecaption 03-24-2012 01:27 PM
Look on the shaft that the trim rings is where you have been chisling. See any threads. I've seen one brand that the ring screwed on.
serpak9 03-24-2012 02:11 PM
Close-Up
1 Attachment(s)
I don't see any threads - I was able to remove a little more of the steel face plate and tried to get a closer picture. I tried to drill through the key hole - but I don't have a strong enough drill and bit.
Attachment 48056
DangerMouse 03-24-2012 02:48 PM
Double keyed DB? Try two pair of vice-grips/pliers, one on each side of the door and unscrew them.
That should do it.
DM
serpak9 03-24-2012 05:02 PM
No Luck
The deadbolt turns and turns and turns, but does not unscrew. Not sure what else to try at this point. :-)
DangerMouse 03-24-2012 05:20 PM
The OUTER RINGS turn and turn while holding them both with pliers?
Impossible.
DM
serpak9 03-24-2012 05:54 PM
Video
I took a video but I can't seem to upload a video to this site. The outside knob turns just a little bit and then sticks. The other side continues to turn, but nothing happens, like turning a screw with stripped threads.
DangerMouse 03-24-2012 06:00 PM
If it's that messed up and stripped, try a sawzall with a metal blade and slice off one side. It'll fall off.
DM
joecaption 03-24-2012 10:50 PM
Do you have a Dremal tool? Use a cut off wheel to split the trim ring.
It would do less damage to the door then a sawall.
DangerMouse 03-25-2012 07:39 AM
Wrong. Exactly the opposite. If done correctly, a sawZall, cutting parallel to the face of the door, will never touch it. Whereas a round cutting wheel on a DremEl tool could easily damage the face of the door.
DM
