Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 04-06-2011, 03:43 PM   #1
Remove and close a window permanently
Look for an easy way to remove an existing window and permanently close the opening.
Outside is siding.
Any ideas would be much appreciated!
Thank you
Tomperro is offline   Reply With Quote
Old 04-06-2011, 04:22 PM   #2
Learning by Doing
Leah Frances's Avatar
Why? I'm only asking because I've spent the last few weeks trying to put windows back where the former homeowner boarded them up.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-06-2011, 04:39 PM   #3
I am moving my kitchen and need the wall spacE for cabinets
Old 04-06-2011, 04:46 PM   #4
Windows & Remodeling
HomeSealed's Avatar
There is really no secret to it. Tear out the entire window frame, add framing and insulation to the opening, drywall the inside, then add sheathing, wrb, and siding to the outside. You'll probably want to pull off some of the siding around the opening so you can build the wall out properly and to the same level, and also to make the seams look more natural. Depending on what type of siding you have, the trick may be finding something to match.
HomeSealed is offline   Reply With Quote
framing two windows very close together ChrisJJ Building & Construction 5 02-09-2011 05:27 PM
Can I tile over the window in my shower? pumpkin8880 Kitchen & Bath Remodeling 3 01-21-2011 10:06 AM
Window Help! GIDGEEGIRL1 Building & Construction 3 10-06-2010 09:46 AM
Window won't close completely bucksone General Discussion 3 06-25-2009 06:57 AM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
