Removal Of Aluminum Windows Stuccoed In - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 01:57 AM   #1
Removal of Aluminum Windows stuccoed in
How do you determine how deep to cut to remove old 60 yr old windows that have been stuccoed into the building structure so that you do not damage any framing or even water barrier underneath if any?
What cutting tool should be used please?
Any advice would be greatly appreciated.
Thank you
Liberator is offline   Reply With Quote
Old 01-24-2012, 07:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
Easiest, and probably most secure installation, will be what is referred to as a frame jump (flush fin) install.
This way you spare the stucco question and utilize the existing frame.
Here is a video from JeldWen. That doesn't mean you need to use that window by any stretch.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
BigJim (01-24-2012), Tom Struble (01-25-2012)
Old 01-25-2012, 04:49 AM   #3
I am in rainy PAC NW so would look to do a nail in flange windows
Any suggestions pls?
Old 01-25-2012, 07:22 AM   #4
Rewards Points: 864
If you want to do a nailing flange, you will need to cut the stucco back to expose and accommodate the new flange.
How are you planning on repairing the stucco or trimming it out?
Acorn Windows are HORRIBLE - Aluminum SmittyNYUSA Windows and Doors 11 10-18-2016 05:33 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Replacing old aluminum windows cocean Building & Construction 2 01-13-2010 06:55 AM
removal nail fin windows tyke125 Building & Construction 8 11-22-2009 01:49 PM
Aluminum patio door removal yeterp Remodeling 2 11-09-2005 12:49 AM
