Reinstalling A Retrofit Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 06:33 PM   #1
Reinstalling a retrofit window
Anyone know if it is very difficult to reinstall a retrofit window? Lowe's installed a window and it is leaking on the inside when it rains. It was a while ago they installed it so it isn't under warranty anymore. It doesn't rain a whole lot in San Diego so we didn't notice it quick enough.
I've actually installed 3 other retrofit windows in my house...none of which leak. Is this simply a matter of pulling the window out, cleaning off everything real good, and just installing it the right way?
Thanks for any advice!
quark is offline   Reply With Quote
Old 11-05-2011, 10:14 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
Where is the window leaking?
Reinstalling the window is no big deal if you pull it out carefully. Cleaning off the caulking is probably more of a hassle.
Old 11-06-2011, 09:42 AM   #3
The windows is leaking from the top part of the sill. I did recaulk it on the outside several months ago when I noticed it leaking due to a gap in the outer caulking. The stucco is a bit concaved at one spot which did make it tricky. The sealer on the inside of the fin must also not be doing anything good.
I did find out a while back that lowe's fired the company that installed my windows and now I know why.
Old 11-06-2011, 10:26 AM   #4
Rewards Points: 2,238
What "W-on-W" says!
Use the right caulk!
"Quad" - "Solar Seal 900" (if you can find it)
Maybe, put a metal "pan" in under the bottom of the window.
Remember - "Drain Plane"!
rossfingal is offline   Reply With Quote
Tags
retrofit reinstallation
Retrofit window flashing question dragondoom295 Building & Construction 1 09-06-2011 08:08 PM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 06:24 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Retrofit Window Installation typerr Remodeling 4 10-28-2009 11:47 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
