Reglazing Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 06:35 PM   #1
bryanp22's Avatar
Rewards Points: 294
Reglazing window
I need to re-glaze my windows. The sashes are in a metal track though. Can I leave the sash in the window and re-glaze. I don't think I need to completely re-glaze just scrape out the bad stuff and basically touch it up.
bryanp22 is offline   Reply With Quote
Old 02-15-2012, 07:26 PM   #2
Rewards Points: 13,950
No way to tell from here, no one here's going to be able to tell you what type window you have without at least a picture. Are these single paned windows?
Metal frames and single paned windows are the about the least efficient windows you can have. May want to look into new windows there costing you a lot of money.
Old 02-16-2012, 08:22 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I wouldn't "touch it up".
Remove all the old glazing and replace. Otherwise the old glaze will take the new glaze with it when it falls out.
titanoman is offline   Reply With Quote
Old 02-16-2012, 08:27 AM   #4
bryanp22's Avatar
Rewards Points: 294
I'll take a picture tonight. The windows are wood the track the window sash is in has like a copper flashing and springs instead of counter weights. I do have storm windows on the outside as well. Here is a pic of the outside that I already had.
Old 02-16-2012, 07:38 PM   #5
bryanp22's Avatar
Rewards Points: 294
Here is a couple pictures. So like I said it is a wood window but the track the sash is in has a copper looking flashing protecting the wood.
Old 02-20-2012, 08:19 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,182
In order to pull that sash you will have to remove the interior stop and pull everything out.
I would not recommend that because it is a bunch more work to get to a relatively simply problem and the copper jamb liners are not very forgiving when they get yanked on to be put back.
Reglaze from the exterior and use something like silicone once you have removed all the old putty.
Old 03-16-2012, 01:47 AM   #7
Heritage Restoration
www.historichomeworks.com
I would use a hacking knife to knock out the old linseed putty. Then oil the area with new boiled linseed oil. The Artist Grade or Allback stuff. Hardware store stuff is so full of contaminants that it rots. Then reglaze with a good glazing putty. Allback or Sarco Dual Glaze.
Wait till it skins and then paint.
Drew Skuce
PSC Heritage Restoration
5-48 Woodslee Ave. Paris, Ont. Canada
www.ParadigmShiftCustoms.com
Skuce is offline   Reply With Quote
Old 03-20-2012, 06:13 PM   #8
bryanp22's Avatar
Rewards Points: 294
The windows are kind of hard to open. Anyone have recommendations on lubrication for the copper sash liners?
Old 03-20-2012, 08:36 PM   #9
Silicone spray.
There still not going to be all that easy to open because there wooden windows that expand everytime the humidy is up but should help some.
Also someone painted right were the sides of the window frames meet the window and stop molding are. It needed to be left unpainted.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
