Refinishing Old Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 07:20 AM   #1
I am refinishing an old door with moldings...I have stripped and sanded the door but I am having a hard time getting all the old paint out of the moldings and corners...any helpful thoughts?
Thank you!
CJ
cjh81 is offline   Reply With Quote
Old 08-05-2012, 07:50 AM   #2
Rewards Points: 13,968
One of these may help.
http://www.bing.com/images/search?q=...835C1BB9D74B7F
Old 08-05-2012, 07:53 AM   #3
Cool thanks!!
Old 08-05-2012, 10:53 AM   #4
Civil Engineer
Rewards Points: 4,854
Paint remover can work wonders. I like the gel kind. READ the directions first, not all paint removers work on all kinds of paint. Some are quite toxic and must be used outdoors. Some recommend use of a NIOSH mask while using the product.
Old 08-05-2012, 05:37 PM   #5
Learning Things Every Day
Jay 78's Avatar
http://www.amazon.com/TEKTON-7063-De...pr_product_top
Under Construction
Jay 78 is offline   Reply With Quote
Old 08-05-2012, 05:42 PM   #6
Nice thanks!! I will get the brushes and give it a shot
Old 08-05-2012, 08:23 PM   #7
Lots of autp parts stores and hardware stores have a cheepo bin full of import tools near the front door. I've seen those type brushes in the bins.
Old 08-05-2012, 09:15 PM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Did you plan to paint or stain it?
I refinished a couple of old panel doors in our last home. I thought I got all of the old paint off. Luckily it was an old stone farmhouse so a rustic look was O.K.
If you are planning on staining it, be meticulous. The tiniest bit of old paint left in the grain will stick out like a sore thumb once you stain.
Also be very careful with metal tools if you use chemical strippers. It will be easy to gouge the wood. I used an old nut pick or a tiny flat head screwdriver to get the tight corners.
Refinishing old wooden doors tban Windows and Doors 4 06-28-2012 05:37 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
Refinishing Garage Doors with Sikkens Cetol 123 AustinPainter Painting 0 08-28-2011 12:54 PM
