Refinishing Door New Weather Stripping Recommendations - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 01:35 PM   #1
bryanp22's Avatar
Rewards Points: 288
Refinishing door new weather stripping recommendations
I am repainting my front entry door and the weather stripping looks to be either bronze or copper, and is like what is the attached amazon link.
http://www.amazon.com/M-D-Building-P...5806872&sr=8-6
The main problem with this type of weather stripping is where the deadbolt and handle set is it basically has no weather stripping. I want to strip the paint from the door, and door jamb and repaint. I am trying to determine if I should leave what is on the door or buy something new. It seems like something like this may work better for a wood entry door.
http://www.amazon.com/M-D-Building-P...ref=pd_cp_hi_2
Anyone have a recommendation?
Thanks.
bryanp22 is offline   Reply With Quote
Old 05-01-2012, 09:29 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Bronze fin weatherstripping works great and is not usually subject to the same over compression and resultant loss of seal that other types are.
Magnetic weatherstripping works great on metal doors but the standard compression style is not as good and the stuff that you already have in my opinion.
Old 05-01-2012, 11:12 AM   #3
Rewards Points: 13,300
I agree that type works great, I was still getting some small air leaks so I added this one in addition and now have 0 leaks.
http://www.azpartsmaster.com/Product..._JAM-UP-1.aspx
Any Hardware, Lowes HD all have it.
It's best to predrill the holes for the screws so you do not strip the heads or split the jamb.
replacing weather stripping on front door cao911 Remodeling 5 09-07-2012 05:29 PM
Help: Replace bottom weather stripping on sliding patio door wakko Windows and Doors 1 08-07-2011 10:44 AM
weather stripping for front door injvstice Green Home Improvement 3 02-04-2011 05:19 PM
weather stripping jad General DIY Discussions 2 10-19-2010 03:36 PM
door weather stripping Gregl13 Remodeling 1 10-08-2010 11:15 PM
