Refilling Argon Thermal Pane Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 04:15 PM   #1
Refilling Argon thermal pane windows
I have double pane thermal doors (sliding glass) I am going to be repairing this summer. Rot has started on the lower half and I'm thinking of repairing them (with pressure treated lumber) and then injecting argon gas in between the panes to keep the insulation value (after of course sealing all the edges with silicon). The argon is easily available from welding supplies stores or even on-line for wine preservation. The atomic mass of argon is 39.95 whereas the atomic mass of air is 28.97 meaning argon is heavier than air (of course factors such as humidity should affect this). So theoretically I should be able to drill two small holes (one to inject argon and one to release pressure) from the top of the repaired door and "recharge" the window after repair.
I know, just replace the sliding glass door. Well, I have thirteen of them. Not all are bad and if I do one, I will have to do them all or they won't match. A small fortune.
Does this sound feasible/workable?
Chiurato is offline   Reply With Quote
Old 03-30-2011, 05:22 PM   #2
Rewards Points: 5,336
You'll need to rethink the pressure treated wood for the doors. Too wet for this application. Use another rot resistant species.
Ron
Old 03-30-2011, 05:38 PM   #3
kwikfishron's Avatar
Rewards Points: 226
My answer is NO.
kwikfishron is online now   Reply With Quote
Old 03-30-2011, 09:41 PM   #4
Originally Posted by kwikfishron View Post
My answer is NO.
Why? Is the argon used for welding unsuitable? Leak problems? Can you give me some input as to your answer? Not trying to be flip, just interested in the logic as to why this wouldn't work. Thanks.
Old 03-31-2011, 08:16 AM   #5
fabrk8r
fabrk8r's Avatar
You won't get all the air out by just trying to displace it with Argon. You would have to pull a vacuum on the space between the panes of glass first like they did at the factory. If you do this you will also find out how hard it is to make a perfect seal using wood.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
Chiurato (03-31-2011)
Old 03-31-2011, 08:25 AM   #6
Rewards Points: 226
Agreed.
The Following User Says Thank You to kwikfishron For This Useful Post:
Thurman (03-31-2011)
Tags
argon , insulation , repair , sliding glass doors
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
Extreme condensation on single pane windows ikessky General DIY Discussions 2 01-24-2011 03:31 PM
Double pane, Low E, Argon filled Windows ChristopherSprks General DIY Discussions 5 01-24-2011 12:10 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 05:46 PM
