Recommendations: What Is The Best Value For DIY Vinyl Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 03:40 PM   #1
Rewards Points: 332
Question
Recommendations: What is the best value for DIY vinyl windows
I have looked at the Pella Series 20 (Lowes) and the American Craftsman Series 70 (Home Depot) but I want to make sure I get the best value for my buck. I am doing these myself and I cannot spend a mint. Any advice on replacement windows is appreciated. Thanks.
tripower is offline   Reply With Quote
Old 07-26-2013, 05:32 PM   #2
Your best value is what you can afford to spend.
Pella 20 and AC 50 (SilverLine window), are probably at the lower end of the spectrum and I will say that you should shop around your area (were ever you are) and see what other brands and series are available to you.
hungryjack is offline   Reply With Quote
Old 07-26-2013, 05:33 PM   #3
P.S. if you HAVE to decide between those two, I'd choose the AC 50.
Old 07-26-2013, 08:43 PM   #4
Davejss's Avatar
Rewards Points: 740
I'm not sure where you live but if there is a Harvey Building Products near you I'd give them a look.
Davejss is offline   Reply With Quote
Old 07-26-2013, 09:08 PM   #5
Rewards Points: 332
I apologize it was the Series 70 I was looking at the 50 is the bottom end product, the 70 is the upgraded window.
Old 07-26-2013, 09:31 PM   #6
Rewards Points: 12,794
Might want to take the time to add your location to your profile. Just got to Quick links to edit.
Suggestions your getting may not apply to you due to location.
I would not take the gift of the two you suggested.
I only use Windcor or Simonton replacement windows. Never had a recall.
If you go on a web site named Pis*ed offconsumer.com you will see hundreds if not more complaints about Pella and there total lack of warranty back up.
Going to have to fill in the missing S.
Old 07-26-2013, 09:51 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 782
Can you get Milgard in your area?
Old 07-27-2013, 08:18 AM   #8
747
registered
747's Avatar
Rewards Points: 534
simonton 5500
747 is offline   Reply With Quote
Old 07-27-2013, 09:26 AM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 710
If you are stuck on box stores, the Simonton 5600 is as good as it gets and my minimum recommendation. Depending where you are located, you should also have some very good options available at the building supply houses such as Softlite or Sunrise, and some Okna dealers sell DIY as well.
I would personally not even consider the two choices that you mentioned previously.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 07-28-2013, 03:05 PM   #10
Rewards Points: 332
Originally Posted by 747 View Post
simonton 5500
How much are those say for a 36 x 46 standard? And where do I buy them?
Old 07-29-2013, 08:28 AM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 710
You can buy them from whichever local building supply house in your area sells them. The 5600 at HD is basically the same window, although I'd still buy from a supply house so you can deal with people who know their stuff and can help you through the process.
www.HomeSealed.com
Old 07-29-2013, 12:21 PM   #12
Agreed.
Old 08-12-2013, 11:32 AM   #13
Rewards Points: 135
I apologize for butting in on this post with my questions but I am also looking at Simonton windows. We went to a local Building Supply House and I was expecting to see some types of Simonton windows in their office but there were none. Makes me a little nervous buying something I didn't get to actually see, other than on the internet, first. This may be the norm for Supply Houses though???, I do not know. I wanted to see how much different they are than the other windows we had replaced - with MI Xact (not keen on these hence looking at Simonton). We are only interested in the vinyl replacement windows so I didn't think the difference in the designs of the window would be terribly noticeably. Secondly, we were looking at either the 5300 or 5500 series - I haven't seen on the Simonton website the 5600 that some of you are mentioning. The lady that helped us has to get a quote from Simonton based on what we want and she will be emailing that to me. Also, we plan on installing ourselves and I wondered if anyone is familiar with their warranty and if this voids it pertaining to installation?
MsKitty32 is offline   Reply With Quote
Old 08-12-2013, 11:52 AM   #14
Simonton 5500 is known by many names, 5600 for HD and Amcraft Grand Estate for ABC Supply, others, but they are all based on the 5500.
The 5500 is a very nice window. Clean lines and they route out their welds for a clean look.
It is solid and typically a good buy.
For warranty, I would call Simonton. They are generally nice and can tell you what you need to know.
I know that if I sell a window like Simonton that I warranty it, but I will come out to make sure that they didn't butcher the job first.
Since you are a homeowner, and I typically like to send people to local supply houses, if you do not feel comfortable with them, don't deal with them. If you FEEL comfortable with a big box store, then deal with them. Its your money spend it the best way you can.
Old 08-12-2013, 04:10 PM   #15
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Good advice above. Simonton is one of the most readily available windows on the market, so just check out a different supply house that has a sample to show you.
www.HomeSealed.com
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Vinyl Replacement Window Questions Marty1Mc Windows and Doors 6 05-22-2011 11:36 PM
Best practice when capping vinyl windows in brick rugby style Remodeling 2 01-18-2011 02:13 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 10:52 PM
