Recommend Basement Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 03:26 PM   #1
Rewards Points: 39
Recommend basement window
We are planning to replace our basement windows due to their poor shape. The current window roughly measures 31" wide and 29" tall and we will be replacing all the framing due to its condition. The basement walls are stone, but on the interior have been covered concrete at some point in the past.
We do have a walk-out basement door and we are not planning on changing the basement to a bedroom, so egress isn't as big of concern.
I am attaching a picture to show our current setup.
What style of window would be recommended? Hopper, awning, casement?
Should we go with custom size or try to find an in-stock size (if so what size)?
KansasCity is offline   Reply With Quote
Old 09-02-2013, 08:08 PM   #2
Rewards Points: 920
I've installed a lot of vinyl 2 block high x 2 block long (16x32) windows and I would think you could go with that style. They can be opened up or down, depending on how they are installed. You'll have to go to the store to see if there is a stock size available for you, otherwise I wouldn't think it would be a big deal to order them.
cleveman is offline   Reply With Quote
Old 09-02-2013, 10:29 PM   #3
MarginallyQualified
Rewards Points: 2,464
Should we go with custom size or...
Most good sized cities still have real lumberyards with a sash shop. Get whatever style they are most comfortable making. Dimensions won't matter.
A new DH window of the same sort you have now should be fine... and would probably look best.
Old 09-03-2013, 11:11 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
If egress is no concern, get whichever you prefer for operation and appearance. I'd definitely go to a supply house or window dealer to order up the proper size. All vinyl windows are custom made to the 1/8" or less, so no need for a "stock" size.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
kwikfishron (09-03-2013)
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 01:06 PM
Basement window finishing Dmoraski Windows and Doors 3 05-29-2012 04:08 PM
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 10:21 PM
Basement flooding around window Brigette Robb Windows and Doors 2 06-21-2011 07:51 AM
Can I build a wall over a window in basement? Rife Building & Construction 6 08-30-2010 07:40 PM
