Realigning Patio Door And Repairing Screen - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 09:09 PM   #1
Send a message via AIM to nathan.hawk Send a message via Skype™ to nathan.hawk
Realigning patio door and repairing screen
So some work needs done on my backyard patio door at my home I moved into last year. Our dog is well sometimes I'll behaved and has really messed up the screen. My realtor had described a fairly simple process where thre is a fairly basic tool that assists with this repair or replacement. Is this basically correct?
Also, I have figured out that the door is poorly lined whereby there is space in top corner and bottom corner because it wasn't put on right. This is really messing with draft in winter months even though the storm door appears to be on correct. Is this a terribly complex job to realign? It is hard to tell how to pop out the door, but I am sure I can figure it out. I can provide photo if needed.
nathan.hawk is offline   Reply With Quote
Old 02-29-2012, 09:10 PM   #2
firehawkmph's Avatar
Rewards Points: 1,902
Post some pics Nathan,
much easier to get some good info back when we can see what we're dealing with.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-29-2012, 09:14 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
http://www.homedepot.com/webapp/cata...&Ntpr=1&Ntpc=1
Door re-alignment is doable but more details are required.
Old 02-29-2012, 09:25 PM   #4
Yeah i'll get some pics tomorrow when there is some light out. Thanks.
Old 02-29-2012, 09:46 PM   #5
Rewards Points: 14,000
http://www.all-about-screen-doors.co...en_roller.html
Most often the screen door and the door just lift up and the bottom tips out to remove.
You first have to back off the rollers on the bottom of the door. Look on the ends for an access hole to get to the adjustment screw, most use a phillip screw driver.
It often takes two people One to lift the door and one with a flat screw to help lift the roller enough to get it out of the track.
Before working on the screen inspect the rollers, often times there shot and need to be replaced. If there bad remove them and take them with you to get replacements. There's dozens of differant styles. Replace all of them if ones bad.
Also check the rollers on the door.
When installing the screen lay it down flat on the deck, start at the top then work your way down one side. When you your ready to to the other side do not pull it to tight, just keep it snug. The roller will pull the screen tight as you work your way down. To tight and you will bow the frame. Once it's all in place you use a utilty knife to cut off the access.
Most likly your door frame is fine it was just the rollers out of adjustment.
Also make sure to clean out the track at the bottom of the door frame.
Old 03-01-2012, 04:36 PM   #6
Here are some general pics:
Realigning patio door and repairing screen-dscf0169.jpg   Realigning patio door and repairing screen-dscf0170.jpg   Realigning patio door and repairing screen-dscf0171.jpg   Realigning patio door and repairing screen-dscf0172.jpg   Realigning patio door and repairing screen-dscf0173.jpg
Old 03-01-2012, 04:43 PM   #7
When you said patio door i was mistakenly thinking a sliding door.
You have a storm door.
Old 03-01-2012, 04:48 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Thats just a sagging storm door. Unscrew the hinge-side z-bar and remount so that it is plumb and the reveals are equal. You may or may not have to pull off the top and latch side as well. Sometimes a long screw through the return on the hinge side will suck it over, but that looks to be too large of a gap... BTW, this is assuming that something isn't damaged or bent.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-01-2012, 05:31 PM   #9
Those full view doors have very little to keep them from sagging.
I'd be checking the door with a framing square.
It may have to be resquared and the screws retightened that hold the frame together.
Old 03-02-2012, 06:18 AM   #10
+1
And get some paint on those jambs before they rot all the way out.
