Re-installing Aluminum Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 02:16 PM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Re-installing aluminum windows
Our house was built in the early 70's. It is brick (inside and out) with original aluminum windows. They are double pane, but single hung.
A previous owner took out two of the kitchen windows and installed a couple of greenhouse windows. The greenhouse windows are poorly installed, have broken seals, are full of condensation, and I'm sure we are losing a tremendous amount of heat due to them.
I have finally convinced DH we should do something about them.
We found the original windows stashed up in the rafters of the garage. I'd like to reinstall them. The bad news is both top sashes are cracked (I assume when they removed them). The bottoms are fine.
I assume the bottom sashes won't be difficult to reinstall, but if I have the tops re-produced (which I can do locally) how are they secured in place? Is there a way for us to do this?
Old 01-24-2012, 06:49 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
While I commend your DIY spirit (you truly are one at heart) I think these windows might be more trouble than they are worth.
Why not just buy a new window in a new frame, with low-e, argon, and a warranty.
The original windows do not have Low-e/argon or a warranty with them. By the time that you have the glass re-made and try to engineer a means of attaching them to the home, it might be a loosing venture.
Just run the numbers and sanity check them.
There is ultimate a cost on your time and that factored in might make this venture a non-starter.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Blondesense (01-24-2012)
Old 01-24-2012, 01:27 PM   #3
Stuck in the 70's
I certainly haven't ruled it out. Just wanted to check out my options.
Thanks!
Old 01-24-2012, 03:29 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'd have to agree with WoW...
If you are on a shoestring budget, look on craigslist or call some of the larger window installation companies in your area and ask if they have any mismeasured/misordered windows close to your size. Even if you have to shrink the opening slightly or something along those lines, it would be more clear cut and deliver a much better finished product if done properly.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows? Erickp40 Windows and Doors 5 11-17-2011 10:53 AM
Replacing aluminum windows installed in 1992 cocean Carpentry 12 09-01-2009 10:24 AM
Help with replacing aluminum windows!! lilerm8302 Building & Construction 2 07-02-2009 12:29 PM
Why is my aluminum wrap around my windows pulling away? Kl483@yahoo.com General DIY Discussions 5 04-21-2009 05:04 AM
Replace Aluminum Windows yellowsky7 Building & Construction 5 09-10-2008 07:03 PM
