Re-glazing Windows. Will This Work?? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 01:43 PM   #1
Re-glazing windows. Will this work??
Iím removing my 1920ís window sashes to make needed repairs including removing the old glazing and glass, cleaning up the wood then re-bedding and glazing. Iím okay at glazing but It occurs to me that instead of using traditional glazing compound, letting it cure and painting it I could use some kind of white plastic material (nylon, acrylic, polywhatever) machined to a wedge shape. The glass would be embedded in a bead of silicon and then use another small bead of silicon to attach the plastic wedges around the parameter and provide a seal, mitering them at the corners. The windows will never be exposed directly to the elements except sunlight as storm windows will be permanently attached. Previous to installing the glass and wedges I could paint the bare wood channels using one of the thin epoxies made for sealing wood. Am I overlooking something or is it simply not a good idea? Thanks.
Mike in Arkansas is offline   Reply With Quote
Old 09-24-2012, 06:21 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Sounds ok,but,there must be some flaw in the logic, somebody will be along to say what.
chrisn is online now   Reply With Quote
Old 09-24-2012, 07:53 PM   #3
Rewards Points: 13,274
#1 How would you ever change a pane of glass once the glass and the trim have been siliconed in place?
Silicone is not paintable.
Old 09-24-2012, 10:02 PM   #4
Rewards Points: 6,652
Just get the Glazing compound in the caulking type tube. As for Silicone type caulks, joecaption, yes there are types that can be painted.
Old 09-25-2012, 12:23 AM   #5
Wasn't planning on great gobs of silicon and don't see a problem replacing a broken pane. I've certainly disassembled other things that had been siliconed together. The point of using a white plastic material is it wouldn't need to be painted and that's the big plus in my mind. Definitely not interested in using a tube type silicon caulk.
Old 09-25-2012, 04:32 AM   #6
chrisn's Avatar
Rewards Points: 228
agreed
69 year young lady struggling with windows robaire Windows and Doors 6 01-18-2012 08:01 AM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 04:39 PM
Replacement windows - flashing question smoenra General DIY Discussions 0 11-02-2011 12:07 AM
Replacement windows not going to work? AnthraciteDude Building & Construction 9 12-11-2010 12:43 AM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
