"R" And "U" Factors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 04:01 PM   #1
"R" and "U" factors
What are the "R" and "U" factors for the Atrium Reliamilt series 3500 windows sold be Lowes - and the same info for the American craftsman AC12 series sold by Home depot?
emscot is offline   Reply With Quote
Old 07-22-2012, 08:35 AM   #2
what you are asking does not seem to translate in my computer, just get symbols/letters. But in general, IMHO, the windows available from big box stores are not worth the time to install them.
There is little craftsmanship in AC windows. I was an Atrium dealer back in the 90's. Only did a few jobs before I found out they were not ready for prime time. Since they are available at big box, I assume nothing has changed.
Old 07-22-2012, 08:40 AM   #3
DIY staff
Rewards Points: 7,174
The site program has got you--let us know what you are saying and a MOD will edit your post so that it makes sense---MOD
Old 07-22-2012, 08:46 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
I think the reason the post is garbled is he copied and pasted the same post from another site, I could be wrong about that though.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
DangerMouse (07-22-2012)
Old 07-22-2012, 10:52 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,908
U-Factor is the inverse or R-Value
The Following User Says Thank You to Windows on Wash For This Useful Post:
BigJim (07-22-2012)
Old 07-22-2012, 05:03 PM   #6
concretemasonry's Avatar
Rewards Points: 2,578
Inverted or not, "U" and "R" values are just short term tests (a few hours) or even worse, based on calculations. They apply to the material properties of thee product (insulated glass, fiberglass, etc.) being tested and not for assemblies used in real construction where edges and framing members can reduce the value properties dramitically when it comes to real uses. They also do not account for other reductions in heat loss or gain, especially radiant loss at night through windows with no opaque or translucent materials or for the normal air infiltration factors common with all installed opening inserts.
Dick
As an example, window with an "R" value of 3.0 is about the same as an uninsulated 6" concrete wall with no drywall or foam. - Fortunately window areas are a small percentage
concretemasonry is online now   Reply With Quote
Old 07-23-2012, 05:54 AM   #7
Dick
+1
They are certainly tests that do not account for the full spectrum of real world simulations, but they are the best that is out there now and they can be used as a comparative benchmark for products.
Proper installation is critical as you mentioned above.
Old 07-23-2012, 12:38 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+2. The U value, shgc, air infiltration, and design pressure ratings may not be 100% representative of how the windows will perform to a "T", but assuming proper installation they are the most comprehensive measure that we have. In addition, the U value is tested over an entire assembled window unit (glass, frame, weatherstripping, etc) and at a mild windspeed.
I would also agree with a previous poster the products in question are not well regarded, and do not have very good ratings comparatively, especially in the area of structural ratings. To answer the question, in standard form they both hit around .30 U-value +/- .01 or so, and that would equally R 3.3. I like to see a double pane unit closer to R4, and triple at R5 (.20 u value) or better. If you live in an extreme climate, you'll want to give extra emphasis in certain areas as well.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
How to increase water pressure? AllGoNoShow Plumbing 26 09-06-2012 08:22 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
tiny mushroom on my grass stupidgirl Landscaping & Lawn Care 2 09-09-2010 07:09 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
