Question On Getting A New Garage Door... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 10:46 AM   #1
Question on getting a new garage door...
My existing garage door measures 9 ft. wide by 6'6" tall. Selection is very limited for that size and was wondering if a 9 x 7 sized door would work?
jtrom is offline   Reply With Quote
Old 02-24-2013, 11:40 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 858
My best advice....spend a few extra bucks and have it installed.....they will cut it down to fit.
Or...you can look at the construction of your opening....you might be able to change the trim boards on the side to increase the size.
Pics of the inside out outside would help.
Old 02-24-2013, 11:44 AM   #3
Rewards Points: 12,914
I've never heard of any over head door comapny that's going to be cutting a door to size.
Got to see a picture of the inside to see if the header can be moved up.
Old 02-24-2013, 12:13 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 858
Joe....that is what they did with mine.....They trimmed a bit off each end so that the panels look centered.
Old 02-24-2013, 01:21 PM   #5
Rewards Points: 2,238
What's the door made of ?
Wood, Fiberglass, Steel, Aluminum?
Probably, not a good idea to try to cut them down -
Unless it's wood.
You're not trimming the ends of the panels -
you'll have to trim the edges (9' side).
rossfingal
rossfingal is offline   Reply With Quote
Old 02-24-2013, 01:41 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 858
Hey Ross....mine is a metal roll up....the ends are basically an end cap that is pushed on. I'll try to take pics later so you can see what I mean..
Old 02-24-2013, 02:59 PM   #7
firehawkmph's Avatar
Rewards Points: 1,800
JT,
if you are looking at a steel door, the sections come in 18", 21", and sometimes 24" heights. They can be mixed to get different heights, usually in 3" increments. For a typical 7' tall door, you would get four 21" sections. For your 6'-6" height, you would get top and bottom sections of 21" an the middle two at 18" each. They don't cut door heights down on section doors. They will cut down the width for custom doors for a fee. That custom sizing varies by company. I happen to have a local door manufacturer that has a shop in house for custom operations.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 09:12 AM
Garage door security! Red Squirrel Safety 32 03-15-2012 02:23 PM
Garage door removal bmorekid Carpentry 2 12-31-2011 11:18 AM
Garage Door Question javan Building & Construction 4 04-25-2011 07:52 AM
Changing Garage Door to 2FT less, footing question Daddioman Building & Construction 14 08-25-2009 06:59 AM
