Protectowrap Not Adhering To Cellotex Fiberboard - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 11:25 AM   #1
Rewards Points: 16
Protectowrap not adhering to cellotex fiberboard
I am installing a new sliding glass door and after installing the rubber flashing on the top of the door, the next morning I came out and the flashing had all fallen back off of the black fiberboard. Someone had told me it is called cellotex. Is any one aware of a product that will stick or do I need to cut back the cellotex and replace it with a wood product similar to whats on the sides? I am getting ready to put all new windows - new construction - (since siding is getting replaced also) and wondering if I will need to do the same thing on all of them. I have include a pic. Thanks for the help.
Speckert is offline   Reply With Quote
Old 07-18-2013, 09:25 PM   #2
Rewards Points: 12,830
I would get rid of the Cellotex. It was a poor idea when it was invented.
In addition to that no way would I install a slider that's that close to a deck without a sill pan.
Been there done that way to many times, most codes call for a minimum of 4", some it's 6" from any door threshold to any solid surface.
The splash back gets under the door and can do thousands of dollars in damage.
http://jamsill.com/
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
How to hang fiberboard with straps Scooby333 HVAC 4 04-15-2013 07:26 PM
Drylining with cellotex 50mm and battens richi3 Drywall & Plaster 0 09-22-2011 06:05 AM
I guess this is a type of fiberboard? Marklar Insulation 0 09-03-2011 11:06 PM
Is there a sealant or resin for Fiberboard? ovsims HVAC 6 02-19-2011 12:33 AM
