Problem with double paned windows
this is glass with a composite spacer ,no how no way is it going to be cheap or easy  ... Seriously though, do you see any signs of seal failure such as condensation or fog between the glass? This is why many prefer metal spacer systems despite a slight deficit in performance. If you don't have any of those issues, replacing the glass will likely do nothing more than improve the appearance.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
