Prehung Interior Door Size Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 01:13 PM   #1
Prehung interior door size help
Hi and thanks in advance
I want to install a prehung interior door.
The old door and frame is removed.
The size is: width from stud to stud 34.5 inches
Height from floor to stud is 81 1/4 - everything removed. No tile etc
Would a 32 by 80 prehung door fit? Online says I need 82 inches height which I don't have.
If not what size do I need?
lornescot is offline   Reply With Quote
Old 11-04-2012, 02:00 PM   #2
Rewards Points: 13,750
Any rough framing on a prehung door is 2" wider then the door size and about 2" on the height.
Just reframe the opening. Far cheaper then paying for a custom door.
Old 11-04-2012, 02:02 PM   #3
funfool's Avatar
Rewards Points: 534
That should work fine, you want 2" bigger width and have 2 1/2" so little extra shimming.
You want 1" taller and you are short there.
Worst case scenario is to cut down the door and jambs by a 1/2", it is common and depends on flooring and such.
Really is no way around it, you are so close it may work, but if you need help cutting down the door and frame you came to right place.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
lornescot (11-04-2012)
Old 11-04-2012, 02:27 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
If you have a reciprocating saw you can notch out 3/4 inch off the bottom of that header and the door will work fine. JMHO
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
installing exterior prehung door, drywall first? mayhem69 Remodeling 8 10-01-2012 07:34 PM
Can I swap a prehung door from one frame to another? diggida Carpentry 10 07-04-2012 01:43 PM
Door from Sunroom to Living Room, Can't use Prehung hoosbekah Windows and Doors 6 03-08-2012 02:28 PM
Door jamb too big for prehung double doors... help please! capth4u Carpentry 18 11-04-2010 12:59 AM
Installing prehung door jdhar Carpentry 9 10-22-2009 08:21 AM
