Prehung Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 03:11 PM   #1
Rewards Points: 258
Prehung door
I have a finished door way, it used to have a folding accorden type door all it had when we moved in was some trim and the top track. I want to install a prehung door do I need to remove the dry wall?
redman88 is offline   Reply With Quote
Old 08-20-2013, 03:46 PM   #2
Old School
Willie T's Avatar
Either go buy the door and jamb... or take a tape to the store... and measure the size required so you can answer this question for yourself.
Willie T
Old 08-20-2013, 03:57 PM   #3
Rewards Points: 258
Ummm that not helpful
Old 08-20-2013, 04:45 PM   #4
Old School
Willie T's Avatar
Then what are you looking (hoping?) to hear? You have to know what size the door going into this opening is (and what the opening is now) before you can even begin to think about whatever modifications may, or may not, be necessary.
Your question is not much different than me asking you if my front yard needs to be mowed today.
Willie T
Old 08-21-2013, 03:10 PM   #5
How big is the opening with the sheet rock?
hungryjack is offline   Reply With Quote
Old 08-21-2013, 06:15 PM   #6
Rewards Points: 258
Wide enough that I had to use a 3/4 board on one side to shim in a 30" door with the sheet rock still in place
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
interesting patio door problems....please help. diybrad Building & Construction 6 11-21-2011 12:52 AM
How To Size a Prehung Door? kc27 Windows and Doors 7 11-05-2011 02:52 PM
Install Prehung Door in 1950 Home ryanb4614 Building & Construction 1 10-12-2011 08:13 AM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 08:45 PM
