Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-26-2012, 12:48 PM   #1
is it possible to mount screen door on this?
inspired by the other thread. i've been digging and can't find a definitive answer to whether i can mount a screen door to the jamb. the clearance appears to be too narrow so i figured i'll post pictures. this is an exposed side door that was built by the previous owners on to a sun room. ideally i want a storm door there but i'm not sure if it is even possible without tearing down the entire deck area. mean goals for this project is to better insulate door area and protect main door for water as there are some rusting already. ideas thoughts? thanks.
http://imgur.com/uANLV,q6kL6,PHi9h#1
http://imgur.com/uANLV,q6kL6,PHi9h#0
http://imgur.com/uANLV,q6kL6,PHi9h#2
vote4Pedro is offline   Reply With Quote
Old 12-26-2012, 01:10 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It is a standard Brick mold frame. Only problem would be to cut away part of the ledge on the left side.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 12-26-2012, 01:35 PM   #3
the storm door if installed will open from the opposite direction as the main door so i'm not too concerned about the ledge. so will the storm door hang out a bit further from the door jamb then? I'm having a hard time visualizing how it can be secured to the frame. additionally is it worth while to install something to shield the door from all the water? here's the picture of the entry way.
http://imgur.com/SOYrM
Old 12-26-2012, 01:55 PM   #4
Mod
kwikfishron's Avatar
The frame of the storm door mounts to the brick mould itself. It doesn’t matter which way you want the door to swing that rail is in the way so you’ll have to notch it or the frame. You need about an inch clear from the inside edge of the brick mould.
Not sure what you mean by shielding the storm door from the water.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Can you mount a storm or screen door on this front door? daluu Windows and Doors 15 12-26-2012 04:55 PM
flat screen TV mount: how to release Ldbudig Remodeling 0 06-23-2012 05:08 PM
Wall Mount Flat Screen Question drb753 Home Theater 3 12-01-2010 03:33 PM
bolt size for flat screen mount bracket bross Appliances 1 11-30-2010 11:09 PM
Wiring for a wall mount flat screen Badfish740 Electrical 4 01-13-2010 08:21 PM
