Pocket Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 03:26 PM   #1
Rewards Points: 83
Pocket Doors
I Have pocket doors installed in my house I just bought. I have adjusted the doors so they go in and out a little bit smoother but still has some slight resistance. I really don't want to replace the rollers because take it a part seems like a headache. Will spraying silicone spray on the rollers help any or should i spray the wheels/rollers with anything to help run smoothly or just leave it alone and replace the rollers soon? Thanks in advance for any input and or advice.
streetneons is offline   Reply With Quote
Old 01-16-2013, 03:56 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
It is not a headache, just that it takes a little bit of time to do it correct, and not mar the wood finish for the trim work. Post pictures. How old is this place? It may be that the roller hardware is needing to be replaced, or needing the bearings lubricated.
As for the resistance, if it is from opening & closing, there is probably something still hanging it up along the roller guide, or the trim is too tight against the door.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
pocket flipper kit for room doors? anuvanoob Carpentry 9 01-06-2016 09:13 AM
Adjust pocket doors Italgrl Carpentry 13 01-15-2013 09:13 PM
100 year old pocket doors valeriephillips Building & Construction 1 03-28-2011 11:44 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
