Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-08-2012, 10:50 AM   #1
Pocket doors
I want to replace my laundry door with a pocket door to make it more accessible. Do I have to remove the existing dry wall?
emra21 is offline   Reply With Quote
Old 01-08-2012, 10:52 AM   #2
Disabled wood vet
titanoman's Avatar
Pocket doors
And some studs.
You need a 6' opening for a 3' door. You sheetrock after the door is installed.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
emra21 (01-16-2012)
Old 01-08-2012, 11:32 AM   #3
Ironlight's Avatar
Pocket doors
Google to the rescue. "How to install a pocket door" =
http://www.popularmechanics.com/home/improvement/interior/4212294
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
emra21 (01-16-2012)
Old 01-08-2012, 01:02 PM   #4
"Nail-Bender"
Pocket doors
Is it a load-bearing wall?
rossfingal
rossfingal is offline   Reply With Quote
Old 01-08-2012, 01:37 PM   #5
Super Moderator
Pocket doors
You need to reframe the wall with a header large enough for the entire pocket door frame---
Also a good idea to fill in the spaces between the 1x4 furring strips with 3/4" plywood---adds some stiffness to the wall and makes the drywalling easier--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Big Stud (01-24-2012), emra21 (01-16-2012)
Old 01-08-2012, 07:03 PM   #6
Pocket doors
Pocket doors are a pain. They are usually flimsy and if they come off the track after the install is done, their a pain to get back on. Don't slam them!
With that being said, follow the directions above, and be careful when you install and adjust the door. And when you put the base back on, use adhesive or short nails.
packer_rich is offline   Reply With Quote
The Following User Says Thank You to packer_rich For This Useful Post:
emra21 (01-16-2012)
Old 01-08-2012, 07:15 PM   #7
Pocket doors
There are some that slide on an exposted track that gets face mounted to the outside wall.
You will still loose some wall space.
Old 01-09-2012, 10:46 PM   #8
Moderator
Pocket doors
Keep in mind that pocket doors hardly stop any sound.......
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
emra21 (01-16-2012)
Old 01-13-2012, 11:22 AM   #9
Pocket doors
I am installing a 32" pocket door from lowes. What is the rough opening size?
DICK SCHOON is offline   Reply With Quote
Old 01-13-2012, 04:09 PM   #10
Pocket doors
Dick read the instructions with your kit. Usually for me it has been 2 times the door plus 1 inch.
mae-ling is online now   Reply With Quote
Old 01-13-2012, 04:11 PM   #11
Pocket doors
I like to put 1/2" plywood on entire area of the door kit, the drywall over that. Have to shim out any other studs on the wall with 1/2" strips too.
Also make sure your drywall screws don't go right through their thin studs and scratch the door.
The Following User Says Thank You to mae-ling For This Useful Post:
emra21 (01-16-2012)
Old 01-16-2012, 07:13 PM   #12
Question
Pocket doors
My issue is this:
We bought this house a guy tried to build his self.
The laundry room has a door to go outside and door to enter the living room.
The doors open into each other which presents an issue because with the washer and dryer it doesn't leave much space to go in and out. I thought since the wall isn't a bearing wall we could put a pocket door in to save space. Sounds complicated! Any ideas or advice on what to do?
Old 01-16-2012, 07:36 PM   #13
Disabled wood vet
titanoman's Avatar
Pocket doors
My issue is this:
It's not that complicated. Go to a supply house and look at one and ask questions about installing it.
100 year old pocket doors valeriephillips Building & Construction 1 03-29-2011 12:44 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
Pocket Doors Question flyultralite Building & Construction 2 02-27-2008 11:35 AM
Pocket doors ? burita General Discussion 2 01-08-2006 10:38 PM
