Plastic Window Edging - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 11:18 PM   #1
Hello Everyone, New Here.
I am having the hardest time tracking down the plastic window edging that goes around the glass. All of the edging has dried and cracked. If you could give me an idea of where to find it, I would greatly appreciate it. Also if you have a good idea on how to remove it and install it I would appreciate it too.
Thank you!
midas is offline   Reply With Quote
Old 09-27-2011, 12:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
It is very likely that the window in question will be more expensive to retrofit/repair than it would be to replace.
If the manufacturer did not intend on making a product that would last, it is very likely they are not still in business.
Could you track down a label on the window to ID the manufacturer or supplier?
Old 09-27-2011, 09:24 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I agree with Windows on Washington... I'd add that replacing the plastic pieces won't do anything for that rotted wood. In fact, the whole frame will probably fall apart if you attempt to do so.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 02:42 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
