Pet Door Into Garage? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-22-2014, 02:02 PM   #1
listo's Avatar
Rewards Points: 93
pet door into garage?
Just bought a new house with an attached garage, gonna put a pet door on the garage man door for the dogs o get out into the dog run, but was wondering if I could do the same for the house door into the garage, then they could go out whenever they want.
My thoughts are that it's not a great idea as the pet doors probably aren't sealed 100% and therefore exhaust gas will have a way to get into the house.
The door is up a set of stairs so it's not on the ground and co is heavier than air?
It'd be nice if they could come and go as they please but it's not that big of a deal if we have to let them into the garage.
listo is offline   Reply With Quote
Old 06-22-2014, 02:05 PM   #2
listo's Avatar
Rewards Points: 93
Here's the pet door I think I'm getting, 3 flaps, does that make a difference?
PetSafe Extreme Weather Door, Large (White) https://www.amazon.ca/dp/B004UORHXK/...XPtb1QYJ9M4RJ6
Old 06-22-2014, 04:07 PM   #3
kwikfishron's Avatar
Rewards Points: 86
Not just that but that door (and wall) from the garage to the house should be fire rated. Cutting a hole in it would compromise that.
They may be out there but I've never heard of a fire rated pet door.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
listo (06-22-2014), Windows on Wash (06-27-2014)
Old 06-22-2014, 04:22 PM   #4
Rewards Points: 6,652
Keep in mind that Pet doors are an easy way for someone to break in. Make sure it is one with the lock on it, that has to be activated by the collar the dog is wearing.a
Old 06-22-2014, 04:33 PM   #5
listo's Avatar
Rewards Points: 93
Good call, forgot about that.
Old 06-22-2014, 05:09 PM   #6
You can always mount a camera in the garage, that would allow you to see the pet door and maybe the entry to the house and garage door. Or even a Pan & Scan like the Foscam FI-9826W IP Camera. It will allow you to zoom in if you want.
Old 06-27-2014, 09:20 AM   #7
Rewards Points: 320
I think you want some involvement with what your dogs do. I'd opt for letting them out when they ask. If dogs can come in, so can other animals. What happens if birds learn to follow in?
carpdad is offline   Reply With Quote
Old 06-27-2014, 12:31 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
I would also be concerned with fumes that communicate as well.
Old 06-27-2014, 04:44 PM   #9
Rewards Points: 346
Agree. Putting it through a fire door into the house isn't a good idea. I partitioned off a small part of my garage with a door in it, then put a doggy door through the outside wall of the house to the dog run. That way, I could leave the dogs outside, and they could come inside the little room in the garage to get out of the weather, but I know what you are trying to accomplish. I'd just let them in and out of the interior door and let them go outside through the doggy door.
taylorjm is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
