Pesky Window Stickers - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 10:09 AM   #16
Sorry if this was mentioned.
Almost every time stickers on products can be removed with the careful use of a heat gun or hair drier. Ideally, warm the glass from the reverse side since that keeps the (if it's plastic) sticker from softening but softens the glue first. Too much heat and glue remains. Just right and the sticker and glue come right off without a trace. Heat until you can lift a tiny corner and lift very slowly while applying heat until right at the point where the glue starts to come away cleanly and that's the right temp.
If you can only get to one side (thermopane for instance) just use more care. Work a tiny corner up and grab with tweezers so you can apply hot air just ahead of the peeling.
If any glue remains I like to use the most 'natural' remedy first which is liberal olive oil and a tiny bit of dish soap. Coat it well. Work it into an emulsion (glue mixed with oil) and then wash with soap/water.
frascati is offline   Reply With Quote
The Following User Says Thank You to frascati For This Useful Post:
forcedreno2012 (07-12-2013)
Old 07-12-2013, 02:40 PM   #17
Renovating My Land Yacht
Rewards Points: 616
Never thought of the heat gun/hair dryer. Thanks for the tip will give that a go on the next batch.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 07-14-2013, 01:57 PM   #18
Rewards Points: 85
Not always. Sometimes the adhesive remains on the glass. But in that case you can simply wipe it off with a rag/paper towel dabbed in acetone or Goo Gone.
huesmann is offline   Reply With Quote
Old 07-15-2013, 06:27 PM   #19
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Be very careful with a heat gun, an imperfection on the edge of the glass can turn into a crack very quickly with concentrated heat. A hair drier shouldn't get hot enough to cause trouble... Can't vouch for whether or not it works though.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
