Pesky Window Stickers - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 04:05 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Pesky window stickers
How do you get these goobers off. I am about to resort to a razor blade but hoping someone here has a hint. When I went to pull the stickers off the new windows half of them stayed on.
Any hints before I screw this up?
Robyn
forcedreno2012 is offline   Reply With Quote
Old 06-25-2013, 06:08 PM   #2
Rubbing alcohol or nail polish remover will break down glue from stickers if soapy water doesn't
creeper is offline   Reply With Quote
Old 06-25-2013, 06:52 PM   #3
Rewards Points: 13,260
Single edged razor to get the main parts off and Goo Gone and a soft cloth for the rest.
HomeSealed (06-25-2013)
Old 06-25-2013, 07:08 PM   #4
kwikfishron's Avatar
Rewards Points: 176
That's been one of my peeves for my entire adult life. Thankfully many of the manufactures have switched to stickers that actually peel off. Now I only get pissed half of the time.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
forcedreno2012 (06-25-2013)
Old 06-25-2013, 07:11 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Razor blade scraper. Go to auto parts store. Then hit with some Windex and 000 fine grade steel wool which will take care of any remaining. Make sure you really wet the window with Windex before hitting with 000 steel wool.
Here is one like i have. http://www.oreillyauto.com/site/c/de...0669&ppt=C0099
747 is offline   Reply With Quote
Old 06-25-2013, 07:44 PM   #6
Rewards Points: 6,652
747, instead of using Steel Wool, use a Clay bar.
Old 06-25-2013, 07:54 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
A razor blade and windex are all that is needed... Just make sure to lube it up with the windex first. Faster than any solvents, although they will ultimately work if razorblades make you uncomfortable.... I worked installing autoglass in highschool and those stickers are 10 times worse than residential windows.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (06-28-2013)
Old 06-25-2013, 08:04 PM   #8
Rewards Points: 616
Thank you all. Have some acetone so will give that a go...if not will grab the razor blade.
HS I hear you on Auto window stickers every time we changed military bases we had to change those stupid things and when you sold your car you had to return them as well.....in a million pieces if necessary lol.
Kwik, I think these were supposed to be peel off but a few weeks in the sun at 90+ and they are not coming off. As annoying as these two windows are I cannot imagine dealing with this for a whole house.
Robyn
Old 06-25-2013, 08:25 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Robyn
Be very careful with acetone.
Very strong and will cause a glaze on clear plastic.
Goo b gone is your best bet.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 06-28-2013, 09:26 AM   #10
Goo-Gone! I buy it at Canadian tire, but its probably carried at H.D or Lowes. The stuff is awesome.....not just good for getting stickers off (and the yucky glue residue) but has lots of uses around the house.
soberjulie is offline   Reply With Quote
Old 06-28-2013, 11:20 AM   #11
Rewards Points: 31
No razor blades. Go to pep boys or auto zone, get a can of invisible glass. Use your wifes dish rag and scrub, then another spray and buff it. this stuff works great, use it on all my windows.
Westbrook is offline   Reply With Quote
Old 06-28-2013, 02:15 PM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 710
No offense westbrook, but I installed glass daily in one form or another for over 15 years, never scratched the glass with a razor blade scraping off thousands of stickers and it is the quickest method by far... I suppose all of that buffing would give you some nice forearms though.
www.HomeSealed.com
Old 06-28-2013, 02:20 PM   #13
Rewards Points: 31
none taken HomeSealed. I've used blades on glass before as well, just another option if you fear scratching your glass. and ya it's a workout.
Old 07-04-2013, 11:00 AM   #14
AHH, SPANS!!!
Rewards Points: 1,166
if the window has a loe E coating then no ammonium based cleaners should be used as per manufacturers suggestion...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
forcedreno2012 (07-04-2013)
Old 07-04-2013, 07:02 PM   #15
Sparkle. It's a compound that gets into the porous areas of the glass. You can find it at most hardware stores.
Amber_windows is offline   Reply With Quote
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
