Pella Vinyl Windows- What Caulking?? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 06:15 AM   #1
pella vinyl windows- what caulking??
New residential construction. What is the best product to use when caulking the gap between the vinyl and interior painted wood trim?
jldec is offline   Reply With Quote
Old 10-17-2011, 06:42 AM   #2
Gaps on interior trim should be VERY small and only need minimal caulking, if any. If you have a big gap, redo the trim.
Old 10-17-2011, 12:50 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
Most installers use Quad but that is some pretty noxious stuff.
A good hybrid sealant or silicon should be fine in your application.
Old 10-17-2011, 03:25 PM   #4
OSI Quad for the strongest, longest lasting and best color holding / mildew resistance.
GottaFixIt is offline   Reply With Quote
Old 10-17-2011, 03:35 PM   #5
Longest lasting...not exactly a proven fact.
Good adhesion, dirt tracking resistant, and paintable...yes.
Old 10-18-2011, 04:27 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Quad is the most commonly used caulk (for windows) among pros, and for good reason imo. Solid product. I would not recommend it for interior use (due to the strong fumes), although they seem far less intense since they brought out the low VOC formula a couple years ago. Silicone is a good choice if it will never need to be painted and you don't need any special color.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-18-2011, 04:50 PM   #7
Rewards Points: 2,238
Outside -
"Quad" or "Solar Seal 900" (if you can find it)
Silicone - maybe not.
Inside -
Already addressed above.
rossfingal
rossfingal is offline   Reply With Quote
Best practice when capping vinyl windows in brick rugby style Remodeling 2 01-18-2011 01:13 PM
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 03:48 PM
Installing new vinyl windows w/ foam&siding Macra Remodeling 3 08-27-2010 07:08 AM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 12:09 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
