Pella Select Storm Door.. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 08:26 PM   #1
valcarmo72's Avatar
Pella Select Storm door..
Has anyone had an issue with sagging? I just replaced the frame. It my second door. It was cheap. Open box special got it for 90 bucks. First one sagged big time. And it was installed right...just wondering if anyone had issues..
Don't know?...ask someone...
valcarmo72 is offline   Reply With Quote
Old 04-10-2013, 08:30 PM   #2
Rewards Points: 13,732
What do you mean you just replaced the frame?
The frame is not going to sag, unless the jambs are moving.
Old 04-10-2013, 08:43 PM   #3
valcarmo72's Avatar
Actually Joe the hinges went bad on my fist one. I called Pella and they basically asked me if I had a contractor put the door in. I said no why would I if u have the express install system. I told them my 4 yr old could get that door in. They basically told.me to screw. The jams were fine.
Old 04-10-2013, 08:45 PM   #4
valcarmo72's Avatar
So I went to lowes. They had an open box I got it for god price. It's basically the jams and screen. I already had the glass and hardware from the old door. I was going for an Anderson 3000 but the price was right...
Old 04-11-2013, 08:27 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,674
I don't know the Pella door you are referencing very well but I can tell you that the Andersen unit is very solidly built.
Instead of trying to make something fit or work with what you got, might be better suited to save the duplicated efforts and just go with the Andersen.
Old 04-12-2013, 03:07 PM   #6
valcarmo72's Avatar
Ur right. I am a huge proponent of do it right the first time. But I save over 200 bucks. Now when I re-installed the same Pella. I put a little bit of thought into it and reinforced the jams with better screws and siliconed them on also. Also I learned in the recent days my wife left the previous door open on a windy day. So that would explain the sag and also the movement in the aluminum at the corners. Let's see what happens. My uncle make aluminum Windows in Italy and he said he can reinforce the door for me so its more solid. He in town soon. But right now the new door is mint...closes on the money with a slam....and the closers seem to be a different model.
Old 04-12-2013, 03:51 PM   #7
I make sure to include a safety spring on any storm door.
That way if the wind catches it, it will stop before damage is done.
Every older Pella door I've seen has failed.
The bottom part leaks and swells up.
HomeSealed (04-12-2013)
Old 04-12-2013, 04:04 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Cheap insurance for just a couple bucks...
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-12-2013, 05:33 PM   #9
Pella doesn't even make their storm doors anymore. That division was sold to Larson Storm Doors about 4 years ago. I agree that the quality of the doors are horrible. I have an Anderson 4000 on my front door, and an Emco 300 (which actually owns Andersons Storm Door division) on my back door. BTW....I am a sales rep for Pella....Pella storm doors are notorius for horrible hardware!
pkrapp74 is offline   Reply With Quote
The Following User Says Thank You to pkrapp74 For This Useful Post:
Startingover (01-28-2014)
Old 04-12-2013, 07:46 PM   #10
There's a web site called Pis*ed off consumers. (you fill in the blanks)
There's thousands of complaints about Pella and all there ad hipe and 0 follow up on complaints.
Old 04-12-2013, 08:53 PM   #11
valcarmo72's Avatar
You Know Joe my mom has a sun room at her house that has all beautiful Pella picture Windows. All wood. Beautiful matching sliding door and all the Windows have blinds in them...there are what u call top quality...about 20 years old...that's when Pella was a good window and door maker. Larson has ruined Pella...the Larson products are better made than the Pella they make now. Storm doors for example....Anderson has gotten a little cheap to but you can buy a top quality from Anderson still.
Old 04-16-2013, 03:38 PM   #12
Pella Windows and Doors
Thanks for sharing your feedback on your storm doors. If you have a question about our products, please connect with Pella Storm Door Customer Service at 1-866-809-9460 Monday - Friday 7:30 a.m. - 4:30 p.m. CST, so we can assist you. You can also email customer service at stormdoorcs@pella.com. We look forward to hearing from you!
Regards,
Erin F., Pella Community Manager
Pellawandd is offline   Reply With Quote
Old 01-27-2014, 05:25 AM   #13
Well yes joe its really important to take safety measures as the high velocity winds during hurricanes and storms often get produced and that generates uplifting effect that can be damaging. Moreover using good film glass for the window same as that coming with the impact windows would do..I guess.Apart from this one can also use great quality frames made up of metal or oak wood or even can also be beneficial.
lillianhofstade is offline   Reply With Quote
Special mounting needed for storm door darsunt Building & Construction 2 04-17-2012 01:38 PM
Installing a storm door Softbreezes Carpentry 4 06-23-2010 06:51 PM
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
