Pella 350 Vs Proline 450 - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 08:07 AM   #16
In the area I live, people all like to go with wood windows. They think the vinyl window give you a cheap look and will reduce the value of the house.
I don't mind the look of 350 but I am really worried about the pocket sill structure since it will get dirtier as time goes and may gets stuck eventually.
What do you think about Pella's Architecture double hung? Do you think it's worth the money since its about 40% more costly than Pella Proline.
What does Pella Architecture compare to Pella 350?
Really appreciate your input.
rqi522 is offline   Reply With Quote
Old 05-28-2013, 08:08 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
If you are going to consider higher end wood, I suggest the Marvin Ultimate.
Old 05-28-2013, 08:11 AM   #18
In the area I live, people likes wood windows. They think the vinyl window has a cheap looking and will reduce the house value.
I don't mind the look of 350 but really concerned about the pocket sill gets dirty and the holes get stuck as time goes.
What do you think about Pell Architecture? Is it worth the money since it costs about 50% more than Proline.
What do you compare Architecture to 350?
Old 05-28-2013, 12:10 PM   #19
Home Performance
HomeSealed's Avatar
Rewards Points: 710
rqi, as I mentioned earlier in the thread, these products are really not meant to compete with each other. It would be like asking which car should I buy: a Prius or an F150? Each can be the right choice depending on what it will be used for. Same with the windows. If you want the beautiful look and feel that only real wood can deliver, then get wood. If you prefer to go on the higher end in performance, low maintenance, and lower cost, vinyl is a great option.
Regarding your pocket sill comment, that is a legitimate concern with the 350, and one reason why many folks don't recommend it. There are other options like Himark, Okna, Softlite, Sunrise, Polaris, etc that offer as good or better performance and appearance but use a welded, sloped sill.
On the wood lines, the main difference between the Proline/Architect/Designer is aesthetic, and varying availability of options. We've installed some of each line with mixed results. Like Windows on Washington, I prefer Marvin if you are looking at wood.
Is there a reason why you seem to be focused solely on options from Pella?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Pella Class Action Suit Bob Deb Windows and Doors 3 12-11-2012 05:10 PM
Anderson 400 or Pella ProLine? Please advise! mystiky Windows and Doors 4 04-19-2011 08:03 AM
Casement Andersen 400 or Pella Proline pankaek Building & Construction 13 03-22-2011 11:41 AM
Pella ProLine preventative measures zacharyw General DIY Discussions 3 11-24-2010 01:38 PM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 01:09 PM
