Paunt - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 10:19 AM   #1
paunt
Do you paint an interior door frame before you hang it or after.
mstbbns is offline   Reply With Quote
Old 11-20-2012, 10:30 AM   #2
Rewards Points: 13,276
After, remove the hinge pins, remove the door, remove all the hardware.
If the doors getting painted lay it flat on saw horses.
I'm going to catch some flack but for me I find it fastest to use a foam 6" foam hot dog roller then back brush it with a 2-1/2" quality brush. The roller gets the paint on the trim faster.
I also use it when painting the door. I use a brush to first do all the low spots and fancy areas then roll the flat areas making sure to also go back over it with the brush where some extra paint may have ran into the low areas.
Old 11-20-2012, 12:31 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,874
No flack from me.
I like the foam rollers. They lay down a nice coat.
