Patio Door Size - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 01:57 PM   #1
Rewards Points: 14
Patio door size
Hi,
We recently purchased a small vacation home. The patio door on the home needs to be replaced...we are not sure of our long term plan on this wall (we might add on to the home)...so did not want to invest in an expensive door yet.
So...we purchased a used patio door. However, I am now having concerns about the door sizes.
The existing door certainly looks and measures to be a standard size and fits into a 72X80 rough opening.
However, the used door we purchased appears to be a bit taller - as the frame is measuring 82 inches tall. It is an Andersen door from 1983 or so...model PSII 6L.
Would Andersen have made a door that is 82 inches tall? See attached measurements from the parts catalog. Do the measurements include the outside door trim?
RickDJ is offline   Reply With Quote
Old 07-26-2013, 02:18 PM   #2
kwikfishron's Avatar
Rewards Points: 1,024
Although 80" doors are by far the most popular 82" doors are available. I've installed many of them.
You would need to raise (not cut) the header to make the 82" work.
kwikfishron is online now   Reply With Quote
Old 07-27-2013, 05:53 AM   #3
I am also agree with kwikfishron you need to raise it up to 82".
ThomasMead is offline   Reply With Quote
Old 07-27-2013, 06:34 AM   #4
Rewards Points: 14,312
Sometimes a "deal" is not such a deal.
Tags
patio door
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Building a new patio cover without footers MStarr Building & Construction 8 01-31-2013 09:06 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
