Patio Door Frame Rot - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-26-2013, 05:56 PM   #1
Rewards Points: 48
Patio door frame rot
I want to cut out the rot at the bottom of my patio door frame (not sure that is the term - it is the center "beam" of a hinged door), but it measures 2.0" x 2.25" and I am not sure the best way to replace that. I thought about joining three 1xs to get the 2.25", but three pieces of wood doesn't seem right. Hopefully I am missing the obvious option...
boogie81 is offline   Reply With Quote
Old 10-26-2013, 06:08 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
It's called the jamb. If you attempt it, use composite.
Old 10-27-2013, 01:23 AM   #3
Rewards Points: 13,260
Post a picture so we can see what your seeing.
Old 10-27-2013, 07:59 AM   #4
747
registered
747's Avatar
Rewards Points: 534
are you seeing any signs of warping?
747 is offline   Reply With Quote
Tags
door , patio door , rot
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 06:20 AM
Building a new patio cover without footers MStarr Building & Construction 8 01-31-2013 10:06 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
