Patching A Hole In An Exterior Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 02:14 PM   #1
Patching a hole in an exterior door
I just purchased a new fiberglass back door and had it installed. I also purchased a pet door and had that installed in the back door. A couple of weeks into the pet door experience, I came to determine that the pet door we ordered isn't working and now need to exchange it for a different model pet door.
The rough cut for the replacement pet door is going to be 5 inches shorter in height than the current pet door. There will be a 5 x 11 space in the middle of the door that needs to be filled.
I'm thinking of using a sized piece of metal, like aluminum, filled with some Great Stuff or something similar. The part I'm looking for feedback on is what to use to fill the small lines of gap space between filler material and the door. Would silicone be good for that or is there something else that would be better for smoothing out those lines? I'm really hoping it's possible to have this hole not be detectable once the doors are exchanged.
Thanks for any info you can offer.
Iron Petunia is offline   Reply With Quote
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Drywall - Durabond for patching a hole ccoulter350 Drywall & Plaster 6 03-06-2010 12:37 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Help - Patching a Hole in a Drywall Ceiling ... njchan Building & Construction 9 04-10-2008 07:56 PM
