Painting Inside Of Vinyl Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 07:36 AM   #1
Painting inside of vinyl window
I am Painting the inside of a vinyl window could you tell me which paint is best to use I am painting it from teratone to white
ntbilodeau is offline   Reply With Quote
Old 08-02-2012, 09:14 AM   #2
Rewards Points: 13,712
Make 100% sure the vinyl is cleaned first, light sanding with about 220 grit paper, clean it off agin then any quality 100% acrilic latex will work.
Old 08-02-2012, 11:33 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'm sure that you are already aware of this, but just in case, please be aware that this will void the warranty of any vinyl window.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (08-03-2012)
retrofit vinyl windows- using wood trim on inside pman6 Windows and Doors 2 07-20-2012 04:33 PM
Vinyl corner guard for bathroom window? CubsWin Windows and Doors 9 05-22-2012 07:40 AM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 06:24 PM
drilling sash on vinyl window rtoni Building & Construction 1 08-05-2008 03:55 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
