Paint Peeling Off Old Wooden Window Frame - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 11:05 AM   #1
Paint peeling off old wooden window frame
Hello everyone,
I have around 5 very old wooden windows all around the basement level of my parent's house. The paint on the frame is starting to peel off and the sealant caulk between the glass and the frame can also be removed easily with the putty knife. There are no visible holes in the wood. I was wondering what is the best way to restore them?
I have zinsser 123 primer, circa 1850 furniture stripper, and 60 grit sand paper
Should I strip the paint that is not firmly attached to the frame using sand paper, prime it and paint it? Or should i strip all the old paint using the circa 1850 furniture stripper?
I have also read about wood hardeners do you think I should use this?
Here are some pictures:
http://i47.tinypic.com/35379mc.jpg
http://i49.tinypic.com/2wml4s9.jpg
It is the first time I work with wood, so I dont know much
Thank you very much
bloudan is offline   Reply With Quote
Old 06-24-2012, 12:10 PM   #2
Rewards Points: 13,300
Post some pictures.
Sounds like a moisture problum forcing the paint off.
Old 06-24-2012, 12:49 PM   #3
Originally Posted by joecaption View Post
Post some pictures.
Thank you for your answer, I already posted some pictures in the first post!
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
peeling paint on plaster paqqj Painting 1 04-12-2011 04:29 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
