-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   overhead garage door (http://www.diychatroom.com/f104/overhead-garage-door-124358/)
awdblazer 11-22-2011 11:20 PM
i just bought a new overhead garage door
i am just wondering if i can just reuse the track and torsion spring with the new door?
thanks!
Windows on Wash 11-23-2011 12:05 AM
As long as they are the same size, it should be fine.
Depending on generation, there may be some incompatibility issues but in theory, it should work.
Just Bill 11-23-2011 07:44 AM
By the same, he means the same weight. Torsion springs are matched to the door weight. It is best to not try and mix old with new.
firehawkmph 11-23-2011 09:56 AM
AW,
When I buy new garage doors from the wholesale suppliers, 80% of the cost of a new door is the sections. The track, springs, and hardware box are minor in comparison. If you picked up a new door, why didn't they sell you the track and hardware along with it?
Mike Hawkins:)
Windows on Wash 11-23-2011 10:23 AM
Ah Ha!
Missed that part. Obviously it depends on the weight of the door but as firehawk mentioned, the components are usually cheap and worth replacing.
awdblazer 11-23-2011 01:45 PM
yah the door i got was everything i was just wondering cause it would save a lot of time
firehawkmph 11-23-2011 03:43 PM
Cordless impact works well, 7/16", 1/2" deepwell sockets. Speeds everything up.
Mike Hawkins:)
rossfingal 11-23-2011 04:16 PM
If you're replacing the door; and , you have new rails, hardware, springs -
that came with the new door - replace everything!
Do it once!
(It takes more time to go back and replace things later)
rossfingal
awdblazer 11-23-2011 09:24 PM
thanks guys that is what i am going to do
you guys have any tips for me?
the manual says takes 9-12 hours to install, is that really true?
Evstarr 11-23-2011 10:00 PM
Only if you're doing it with your feet.
3-4 is realistic if you're reasonably efficient.
Windows on Wash 11-24-2011 10:54 AM
Do it once!
rossfingal
+1 on both accounts.
Get the deep well sockets and a cordless impact driver.
3-4 hours is much more realistic.
Ron6519 11-24-2011 12:21 PM
If you've never done a garage door before, I would plan on 6 hours.
rossfingal 11-25-2011 07:16 AM
"awdblazer"
I just re-read your post.
"Torsion" springs!
If you have "torsion" springs and not "extension" springs -
Installing "torsion" springs can be a "DIY" project.
I wouldn't suggest it!
I've installed "torsion" springs and adjusted them - a long time ago.
Became friends with "pro" garage door installers -
They told me of the potential dangers of "playing" with them!
They play rough!!!
(Injury - death!)
I don't "play" with "torsion" springs anymore!
Install the door -
Then call a "pro" and have them adjust the springs -
Safer! :)
It'll, probably take them about, an hour.
rossfingal
awdblazer 11-25-2011 08:04 AM
i can adjust these springs with a drill
oh'mike 11-25-2011 08:38 AM
That type should be O.K. to DIY---the more common ones that take a rod or wrench to adjust are to dangerous for me----I once saw the adjusting rod stuck into the roofing 10 feet away when the pro lost grip----that thing would have changed his life if it hit him.
