Outside Window Stop Question... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 11:16 AM   #1
I completed my first DIY window install yesterday...since I am a teacher I give myself a grade of a B. My 2 questions are this.
1.) I am not even sure if I installed the window correctly, but I know it is plumb, sealed, and opens and closes. The outside window stop is exposed (see pictures) and I was wondering if I can just sand off the old paint, prime, and paint with an exterior paint.
2.) I guess that leads to my second question, as I do not want to re wrap the window with aluminum, can I simply use an exterior paint to paint the existing window wrap?
Any help is appreciated, this site is great...I get such good reliable advice!
dukes32 is offline   Reply With Quote
Old 06-11-2012, 05:07 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Sure you can, just remember to prime any bare wood before you paint.
kwikfishron is offline   Reply With Quote
Old 06-11-2012, 05:50 PM   #3
Thanks Ron,
Any Suggestions on what type of paint to use for the Aluminum Window Trim?
Old 06-11-2012, 06:00 PM   #4
Rewards Points: 86
I'd use SW superpaint but I'm no paint pro.
Go to a SW, Ben Moore or a local brand paint store (not a box store) and ask them.
Keep in mind that the aluminum is likely PVC coated so you're not really painting aluminum.
Old 06-11-2012, 06:18 PM   #5
Always appreciated! Thanks for the help.
Old 06-12-2012, 10:28 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
+1 to KFR's advice... The only thing that I'd add is that it would be very easy and inexpensive for you to trim those blindstops in aluminum for the sake of uniformity. If you'd rather paint, add a bead of caulk from the existing cap to the blind stop.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-12-2012, 11:06 PM   #7
Thanks, HomeSealed...I know nothing about bending metal, but this might be a good way to learn/start. How would I bend the metal w/out a metal bender? Something maybe I could rent?
Old 06-12-2012, 11:40 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 710
You can rent a brake from Home Depot. It looks very intimidating, but in your case, you only need one bend in each piece to form it in the shape of an "L".
www.HomeSealed.com
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 05:39 PM
2x6 window header question MoneyPit3 Building & Construction 12 04-02-2012 03:01 PM
quick door and window question wengang1 Drywall & Plaster 4 12-09-2010 05:24 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
