Out Of Square Window How Best To Install - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 10:49 PM   #1
Rewards Points: 1,604
Out of square window how best to install
This is really a continuation of another thread but I opened up a can of worms and this is another issue. Basically I have a double window (one top, one bottom) with a metal brace in the middle.
The original install was very sloppy and so I took everything out and redid the buck and the horizontal aluminum brace.
I fitted the bottom window and it works great. I then removed the bottom window and tried the top window.
Now, I checked, double checked, triple checked. The rectangular opening, the three sides, and the bottom aluminum brace, are all level and plumb.
However, when I fit the window in, it looks strange from the inside. There is a gap about 1/4"+ on the top edge on the left, and the left edge to the bottom, and the right edge to the top. Most of the time I would assume the window is square and the opening is not, but I checked, the opening is square, the window is not!
So first question, is 1/4" over a length of 24" out of square significant? Should I even worry about it?
I am sure after I finish it I wouldn't be able to tell visually along the edges, the only clue would be when I open or close the window all the way, one of the pane is not totally parallel with the other by the same amount.
Now normally I can fudge it a bit because I can shim a little here and there on four sides on a regular window, but this one has a metal brace it must attach to so it MUST be flush against that.
More pictures:
I even put a carpenter square to one side and you can see the sliver of space from top to bottom going from 0 to 1/4".
May be the original installer stretched the frame during installation and distorted it? Possible?
miamicuse is offline   Reply With Quote
Old 04-18-2013, 12:15 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
it really doesn't make much difference how it sits in the opening for anything but appearance, but it is important how the sashes sit within the frame. That is where you want consistent margins... If you open the window about a 1/4" and look at the margin from top to bottom between the sash and frame, it should be visible consistent. If not, it will not seal fully.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-18-2013, 08:38 PM   #3
Yes, if I slide the window open a little or all the way open, the "margin" as you called it is NOT consistent from top to bottom. One is 1/4" more than the other.
Old 04-18-2013, 11:07 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
If that is the case, you are not going to get a good seal.
www.HomeSealed.com
Old 04-19-2013, 11:55 AM   #5
OK thanks.
Is this a problem that can be repaired? I mean if I take this window to a window store can they fix it?
Old 04-19-2013, 02:34 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Either the frame is racked which can be addressed during installation, or the sashes aren't riding on a flat surface which is causing that. Based on your pics (especially number 2), it looks like something that you can fix with some strategic shimming. Put the level and the square back in your toolbox, and install the window looking only at those margins. To me, it looks like the upper left side needs to be shimmed over.
www.HomeSealed.com
Exterior Finishing of a New Constr. Window Install (siding etc.) DefyInertia Windows and Doors 3 04-11-2012 12:29 AM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 10:34 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
