-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Out of square window how best to install (http://www.diychatroom.com/f104/out-square-window-how-best-install-177424/)
miamicuse 04-17-2013 10:49 PM
3 Attachment(s)
This is really a continuation of another thread but I opened up a can of worms and this is another issue. Basically I have a double window (one top, one bottom) with a metal brace in the middle.
The original install was very sloppy and so I took everything out and redid the buck and the horizontal aluminum brace.
I fitted the bottom window and it works great. I then removed the bottom window and tried the top window.
http://i173.photobucket.com/albums/w...psdb5de11a.jpg
Now, I checked, double checked, triple checked. The rectangular opening, the three sides, and the bottom aluminum brace, are all level and plumb.
http://i173.photobucket.com/albums/w...psabef5f93.jpg
However, when I fit the window in, it looks strange from the inside. There is a gap about 1/4"+ on the top edge on the left, and the left edge to the bottom, and the right edge to the top. Most of the time I would assume the window is square and the opening is not, but I checked, the opening is square, the window is not!
So first question, is 1/4" over a length of 24" out of square significant? Should I even worry about it?
I am sure after I finish it I wouldn't be able to tell visually along the edges, the only clue would be when I open or close the window all the way, one of the pane is not totally parallel with the other by the same amount.
Now normally I can fudge it a bit because I can shim a little here and there on four sides on a regular window, but this one has a metal brace it must attach to so it MUST be flush against that.
More pictures:
http://i173.photobucket.com/albums/w...ps901d80fa.jpg
http://i173.photobucket.com/albums/w...pseca5f016.jpg
I even put a carpenter square to one side and you can see the sliver of space from top to bottom going from 0 to 1/4".
http://i173.photobucket.com/albums/w...ps31435a5b.jpg
May be the original installer stretched the frame during installation and distorted it? Possible?
HomeSealed 04-18-2013 12:15 PM
it really doesn't make much difference how it sits in the opening for anything but appearance, but it is important how the sashes sit within the frame. That is where you want consistent margins... If you open the window about a 1/4" and look at the margin from top to bottom between the sash and frame, it should be visible consistent. If not, it will not seal fully.
miamicuse 04-18-2013 08:38 PM
3 Attachment(s)
Yes, if I slide the window open a little or all the way open, the "margin" as you called it is NOT consistent from top to bottom. One is 1/4" more than the other.
HomeSealed 04-18-2013 11:07 PM
If that is the case, you are not going to get a good seal.
miamicuse 04-19-2013 11:55 AM
3 Attachment(s)
OK thanks.
Is this a problem that can be repaired? I mean if I take this window to a window store can they fix it?
HomeSealed 04-19-2013 02:34 PM
Either the frame is racked which can be addressed during installation, or the sashes aren't riding on a flat surface which is causing that. Based on your pics (especially number 2), it looks like something that you can fix with some strategic shimming. Put the level and the square back in your toolbox, and install the window looking only at those margins. To me, it looks like the upper left side needs to be shimmed over.
