OSB Vs Plywood For Window Padding/shimming - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-10-2015, 03:25 PM   #1
Rewards Points: 1,062
Question
OSB vs plywood for window padding/shimming
I need to use 1/2" plywood or OSB on both vertical sides of my retrofitted window frame. I was wondering if there is any difference in OSB (cheaper) vs plywood (more pricey) for this application considering that if somehow moisture got in (which I'm making sure it doesn't but who knows) and the material gets soaked and swells (like I think OSB is more likely to in moist conditions), it may squeeze the window on the sides too tight, causing it to break.
Old 11-10-2015, 03:54 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
No difference.
Holding is really at the stud anyway.
You shouldn't be getting water in there anyway.
The Following User Says Thank You to Windows on Wash For This Useful Post:
amakarevic (11-10-2015)
Old 11-20-2015, 11:44 PM   #3
Registered User
Rewards Points: 526
Just paint the OSB edge on the weather side to sleep at night; http://parr.com/weekend-warriors/ply...ich-is-better/
Gary
Old 11-21-2015, 06:18 AM   #4
Rewards Points: 3,861
I was building out at the framing level to bring the studding even with the brick to brick for replacement windows.
I choose plywood and covered all but the narrow room side with Protecto wrap. Probably overkill since water should not penetrate to that area but it did not cost that much extra and I know I did the absolute best that I could do.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Tags
osb , plywood , shim
Combining Plywood over 2x4s mulvihwm Carpentry 1 09-14-2015 12:32 AM
Staples or screws on plywood subfloor? And other questions.... howdihi Flooring 1 08-18-2011 08:50 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
