Options For A Not So Squared Shower.. Glass Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 07:17 PM   #1
Rewards Points: 198
options for a not so squared shower.. glass door
i built a DIY standing shower in the basement and i now need a shower door to complete the project. i thought i was going to do a frameless glass showerdoor but it appears that i did not built the wall not soooo straight. long story short, so i thought i was doing something fancy with the left wall by doing a 2 part wall (13inches from the ceiling and waist height form the floor) leaving a gap for a glass panel in the middle.. the problem is that since my floor is not very flat, the 2 wall pieces are at slight different angles. this leaves the door opening itself to be 30 inches at the top while 31 inches at the bottom..FAWWWWKKKKKK!!!!!! so what can i do to fit a door in there.. is glass door still an option? i'm considering hanging in a shower curtain to hide my shame..
tx for the advice.
vote4Pedro is offline   Reply With Quote
Old 03-02-2012, 06:19 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,294
Custom glass shop can make a glass door to fit just about any space.
Post up a picture.
Old 03-02-2012, 08:05 AM   #3
Rewards Points: 198
a custom glassshop will run me close to $1600.. at this point, is it even worth it to hand a glass door there?
Old 03-02-2012, 10:19 PM   #4
Rewards Points: 198
i'm considering knocking down the top wall... really hate that thought.
before i start, is there more lead way with a framed door?
Old 03-03-2012, 04:59 AM   #5
DIY staff
Rewards Points: 7,174
Yes--there is adjustment on the catch side--some have as much as an inch--
also some adjustment on the hinge side--
Get the installation instructions--or look at the actual right and left side tracks to see for your self.
Old 03-03-2012, 10:21 AM   #6
Rewards Points: 81
Check out wilson glass...they make custom/to order glass enclosures that they ship to you as a DIY install. I've heard great things about them and intend to use them for my shower when I get to that point.
JeepNick is offline   Reply With Quote
Old 03-05-2012, 08:10 AM   #7
Rewards Points: 198
thanks for the help. i've emailed wilson glass for a quote. currently i'm considering a lower door (65 inches) instead of the standard 72. this will allow me to have door slightly below the top wall.. hopefully that will address the issue.
Glass block window in tiled shower stall ddmcc Windows and Doors 16 01-04-2012 10:48 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 11:22 AM
Kohler shower door, tolerances, not sure which size to pick mslide Kitchen & Bath Remodeling 2 12-04-2009 11:08 PM
glass shower door removal ross General DIY Discussions 1 04-25-2005 06:22 AM
