Opening A Skylight Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 12:18 PM   #1
Opening a skylight window
I am interested in opening my skylight window in order to obtain rooftop access. Right now the window is inserted with some sort of shabby tar. I myself have some building experience but never inserting a window in the ceiling. Any advice on where to get started? Or even how to get myself an estimate for such a thing? Thank you! Sam
Samstone is offline   Reply With Quote
Old 01-17-2013, 12:27 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
So are you saying that you would like to replace an existing "fixed" unit with one that is operable, in order to get access to the roof as needed?... Or are you trying to figure out if there is some way to open the unit that you already have?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-17-2013, 12:41 PM   #3
Rewards Points: 13,300
What's wrong with using a ladder to get on the roof?
Old 01-17-2013, 01:24 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Let me also add that when you mentioned "installing a window in a ceiling", I assume that you are referring to a proper skylight. An actual window should never be installed in a ceiling/roof.
...I'm sure that is the case, I just had to make sure
www.HomeSealed.com
Basement windows Toddr Windows and Doors 3 10-31-2012 07:14 PM
Velux skylight opening amakarevic Building & Construction 8 05-16-2012 04:05 PM
Skylight ceiling opening mt232 Remodeling 2 05-15-2012 05:00 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
