Opening A Door That Changes Depth - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-28-2014, 09:58 AM   #1
Rewards Points: 14
Opening a door that changes depth
I am creating a theater room and there will be acoustic panels on the walls, and probably the doors as well. I am looking to have deeper panels up high which then get shallower towards the floor. I am wanting the door (with panels) to be flush with the walls. Is there a way to do this without having the lower hing sticking out a few inches?
Kevinicus is offline   Reply With Quote
Old 09-28-2014, 10:39 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,674
You can offset the set in the wall and have the hinges more flush but it depends on the swing direction.
You will have to make the door outswing away from the panel side of the wall if you want the hinges to be buried and are using a standard swing door.
turning basement into apt sherilyn Remodeling 4 11-07-2012 07:56 AM
how to go about making a window bigger in my basement so that I can put a bedroom urgurl031 Remodeling 12 10-07-2012 05:26 PM
stairwell opening in wood joist floors Galatea Building & Construction 8 10-13-2010 01:37 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
