Old Windows - Unable To Lock - Sashes Not Lining Up - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 03:31 PM   #1
Post
Old Windows - unable to lock - sashes not lining up
Hello DIY group,
I am new to this site. I have some very old wood windows (originals to my house which was built in the 1920s), many of which do not have locks. The previous owners of my house had purchsed a lot of metal locks but never installed them because they found that the sashes are not lining up and it is impossible to lock the windows by just adding the locks. A window restoration group came by recently and told me I could just add 'metal shims underneath the new locks' and this would raise the lock enough to align it with the other sash. Has anyone done this before and if so - what are these metal shims? Where can I get them? And is there anything you suggest I keep in mind if I plan to do this myself? Would love your thoughts/ideas
Thank you!
JohnMargaret is offline   Reply With Quote
Old 11-05-2013, 03:37 PM   #2
Rewards Points: 13,256
Washers will work.
Make 100% the top sash is all the way up first. More often then not it's slipped down and is stuck from all the old paint. Break it free by cutting the paint line and see if it will tap back up.
JohnMargaret (11-05-2013)
Old 11-05-2013, 03:42 PM   #3
Hey Joe,
Thanks a bunch. I had not thought of washers. The window restoration guy and I both have tried to push the top sash back up and have not had any success getting it up any further but I will give it one more try. Restoration guy seemed to think all of the windows were like this from the house settling over the years. Our contactor (who is working on other projects) seemed to think the windows had been taken apart and put back in incorrectly at one point. Regardless, just hoping to get some locks on them. Thanks for the tip!
Old 11-05-2013, 03:46 PM   #4
If the bottom one is sitting to high why not just remove the window and cut some off the bottom?
Old 11-05-2013, 03:48 PM   #5
The window guy suggested either cutting off the top of the top sash or adding shims. He thought shims was the best way to go since it was less likely to 'compromise the windows'. Any thoughts on that?
Old 11-05-2013, 04:10 PM   #6
We have no idea how far it is or in what direction.
No way would I be adding shims.
Old 11-05-2013, 04:13 PM   #7
Just curious, why would you not be in favor of adding shims? By the way, not sure if I mentioned that 12 windows are this way
Old 11-05-2013, 06:29 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Do you have any concern with regard to the windows being energy efficient? Or are you just trying to address the locking issue for security?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 11-06-2013, 08:38 AM   #9
biggles's Avatar
how about shaving the bottom of the windows either one or both to marry up the top to bottom so the locks line up when installed.jig saw or chisel little at a time...how off are the middle section when the window is closed?
Old 11-06-2013, 09:00 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
Similar windows here. If you can, decide on whether you will restore your old windows or eventually replace them. Restoration is a pure act of love because it is irrational to do so unless you are driven by something other than logic. That said, there are many people that practice this labor of love so don't feel like an odd ball if you are one of them.
Plan A:
Windows will get replaced. Screw em shut and removable caulk any leaks for now. Screws and caulk can be easily removed to operate windows if need be.
Plan B:
Expect to put about 40 to 80 hours in on each window to put them back in like new condition. Strip paint, re-glaze, replace sash cords, etc. etc.
My top sashes have stops on them to keep them up. You can look at them from the outside and see if they are up all the way if you are not sure. Once all the layers of paint are removed from the frames and stool you may find they line up perfect.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
JohnMargaret (11-06-2013)
Old 11-06-2013, 10:41 AM   #11
At this time I am just trying to address the locking issue with these windows for security. I am replacing a few of the other windows now and will replace at least one other later.
Old 11-06-2013, 10:49 AM   #12
I can take pictures tonight if this would help.
Old 11-06-2013, 02:11 PM   #13
PoleCat's Avatar
Since you are slowly replacing them there is no need to put a ton of work into any of them. Screw a small block of wood into the channel the bottem sash rides in. Window locked.
Old 11-06-2013, 04:24 PM   #14
biggles's Avatar
drill a hole into both sections that overlap in the closed position and slip a common nail in one on each corner...same with the track drill a hole on the right and left sides just above the lower closed section and slip a nail into there
Tags
old windows , shims , windows
Replacement windows - flashing question smoenra General DIY Discussions 0 11-02-2011 12:07 AM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
