Old Pocket Door Hardware - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 02:04 PM   #1
Rewards Points: 857
old pocket door hardware
does anyone have experience removing pocket doors on older hardware? i can get the door(s) into the opening and able to swing them, but they are double wheeld axles in two sided tracks, so they don't just lift off. there must be a method to release the trolley from the wheels. the track appears to be screwed into cast iron brackets with captive screws. Thanks.
TimPa is online now   Reply With Quote
Old 02-16-2013, 02:08 PM   #2
Rewards Points: 13,732
Got a picture?
Old 02-16-2013, 02:09 PM   #3
Rewards Points: 857
wish i did.
Old 02-16-2013, 02:49 PM   #4
Framing Contractor
Rewards Points: 120
You can usually unscrew the track, let it droop as you swing the door down and out, then slide it off of the track. Lot of different old pocket door dardware.
sixeightten is offline   Reply With Quote
Old 02-16-2013, 08:11 PM   #5
DIY staff
Rewards Points: 7,174
Track and trolly stay put---the trolly often has a release where the post meets the top of the door---
some times it will have a jamb nut that keeps the trolly drop post from coming loose from the door top plate---
How old is it? I have worked a few of these--1863 what the oldest---
Installing Switch in Pocket Door Wall JulesB Electrical 25 11-19-2014 11:40 AM
Shower next to pocket door? CMB00 Kitchen & Bath Remodeling 12 01-08-2013 06:58 PM
Pocket Door Wheel AZSun Carpentry 2 10-09-2012 09:01 PM
pocket door between kitchen and laundry jarleifvaagen Building & Construction 7 02-13-2011 07:55 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
