Old Garage Window Has Small Panes, One Needs Replacing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 05:38 PM   #1
Old garage window has small panes, one needs replacing
What kind of caulk would I use on the outside to attach the glass pane, and make it sealed and waterproof?
Judy Roberts is offline   Reply With Quote
Old 05-24-2012, 05:58 PM   #2
kwikfishron's Avatar
Rewards Points: 410
Welcome to the forum Judy.
You want to use "window glazing compound" not caulk.
There are plenty of YouTube videos that can show you the process.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
HomeSealed (05-24-2012), Judy Roberts (05-27-2012)
Old 05-24-2012, 06:08 PM   #3
Rewards Points: 13,458
Going to need way more info on exactly what it is your trying to do.
Pictures would be really helpful.
Old 05-24-2012, 06:30 PM   #4
Old 05-24-2012, 07:15 PM   #5
DIY staff
Rewards Points: 7,174
The stuff that Kwikfishron is talking about is a simple process--
About all you need is a narrow putty knife---
Remove the old glazing compound (a sharp knife helps)--check and see if the glass is secure-
Add a few 'glazing points' if the glass is loose--they are little flat metal pin that are just pushed in with the putty knife---Dust off the work
The glazing compound is like soft children's clay---roll a snake out of the putty--press in to the wood with the putty knife--smooth it out with the blade---wait a week to paint--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Judy Roberts (05-27-2012), kwikfishron (05-24-2012)
Old 05-24-2012, 07:23 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Based on the description, I'm gonna say that kwikfishron nailed it on the head.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following 2 Users Say Thank You to HomeSealed For This Useful Post:
Old 05-24-2012, 08:00 PM   #7
Rewards Points: 410
Ya know, now that this all got brought up I've seen glazing compound in a caulking tube with a special tip.
Anyone ever used the stuff?
Old 05-24-2012, 08:09 PM   #8
DIY staff
The old fashioned way is so simple that I never tried that caulking tube stuff--
Replacing window sash issue TallCoolOne Windows and Doors 2 06-27-2011 06:38 AM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
Replacing a window whattodo Remodeling 3 03-08-2010 06:51 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
