Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-05-2012, 12:55 AM   #1
old dual pane vs modern dual pane
I have the 1990 dual pane windows that builders put in.. aluminum frame and all and I can hear the street outside it is fairly loud.
On my previous home I am closer to the freeway and louder outside,
but do have newer windows (2000 era) and it seems quieter.
I am curious the new vinyl window and newer dual pane window will make that much of a difference to noises outside.. I am guessing the aluminum frame adds as kind of a speaker/coil and resonate the noise worse than a vinyal frame window?
DIYGST is offline   Reply With Quote
Old 12-05-2012, 08:42 AM   #2
Exterior Construction
Windows on Wash's Avatar
There is a bit more vibration through the frame materials in that comparison and it is likely that the newer unit had thicker glass as well.
Old 12-05-2012, 12:14 PM   #3
Windows & Remodeling
HomeSealed's Avatar
+1. There is most likely a lot more air moving through the old unit and carrying that sound as well .
HomeSealed is offline   Reply With Quote
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 03:05 PM
dual pane windows kathleensr Building & Construction 1 11-07-2010 03:35 PM
Dual pane window seals Astrozombie Remodeling 2 11-29-2007 07:38 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
