Old Double Hungs - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 12:57 PM   #1
old double hungs
i have several double hung windows that need to be replaced i would like to replace with a tilt in double hung. the issue i have is the exterior is vinyl sided and the windows have a 1x5 (4 1/2") board on the outside holding the windows in place. j channel butts up to thge 1x surrounding the outside of the windows. so my question is, i want to put a new unit in that would butt up to the j channel and get rid of the 1x5 exterior trim but i don't want to peel the siding and j channel back to nail a flange from the new window unit, is there a unit that does not use the exterior flange for the install, i did replace the sashes years ago but now i want to replace the whole unit with say a narrow line style to match the rest of the windows in the house, but i don't want to peel the siding back or remove the j channel thank you
chairguy is offline   Reply With Quote
Old 11-30-2012, 07:44 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
I have the same old windows. You should have framing there that a new const. window can be be attached to inside the line of the j channel. But you will have to figure out a way to fill in the gap that will look ok and caulk the pee-waddin out of it.
PoleCat is offline   Reply With Quote
Old 11-30-2012, 08:10 AM   #3
Rewards Points: 13,450
Got a picture both inside and out?
Trying to figure out how you plan on removing the outside trim and making up for that gap once it's gone.
By far the most damage I've seen done to outside walls around a window is from what's called flat jamb windows like I think your suggesting.
Just no great way to air and water seal by just counting on J moulding and caulking. Caulking always fails at some point and may trap the leaking water behind it.
Old 11-30-2012, 05:19 PM   #4
PoleCat's Avatar
These old windows are attached only by this trim. Like a nailing flange. Top and both sides, nothing at the bottem. I wouldn't worry so much about getting a good seal as getting it to look right. The bottem would not have any margin.
Help with finding weatherstripping for my old (mid 1960's) wood sash double hungs! 240sx4u Windows and Doors 0 10-25-2012 12:13 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 12:44 PM
